texascherokee Posted May 30, 2014 Share Posted May 30, 2014 What kinda of steel would they be considered? I have 2 of them and they are probably 3/4" thick. I want to use them but I don't wanna waste them if they would be good for something like a drift or slot punch or even chisels. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted May 30, 2014 Share Posted May 30, 2014 They are a type of spring steel, so treat them like leaf, or coil springs. Some are hollow by the way. Quote Link to comment Share on other sites More sharing options...
texascherokee Posted May 30, 2014 Author Share Posted May 30, 2014 These ones are solid. They came off of 4x4 Jeeps. Quote Link to comment Share on other sites More sharing options...
Glenn Posted May 30, 2014 Share Posted May 30, 2014 Still check to be sure they are not hollow. If they are use them as pipe. Quote Link to comment Share on other sites More sharing options...
texascherokee Posted May 30, 2014 Author Share Posted May 30, 2014 Still check to be sure they are not hollow. If they are use them as pipe. I'll cut one open and check it out. Quote Link to comment Share on other sites More sharing options...
Glenn Posted May 30, 2014 Share Posted May 30, 2014 Good idea to find out if it is hollow BEFORE you start heating it. If it is hollow you will need some way to vent any pressure that may build up from the heat. (think heating a closed container). Quote Link to comment Share on other sites More sharing options...
