May 24, 201412 yr My buddy Mark spied this anvil sitting in the dirt under the drip line of a barn roof. He struck a deal and brought it home. We're both curious to it's approximate age and origin. I spent a lot of time with a wire brush in different light conditions, any stamps or markings are long gone. The horn has 2 parallel lines that have aged in. I'm suspecting the manufacturers had laid in a strip of tool steel along the top of the horn, and it resisted wear more than the wrought base? It's cracked where the horn base connects to the waist, but still workable for light duty. Somebody had bushed the hardy hole with a piece of pipe. It's going to soak for a week before we try and remove it. We'd love to hear any clues to where and when it was born. thanks, mike
May 24, 201412 yr Just think if that anvil could speak and tell you how it got to the West Coast, and when. And what myriad of objects have been forged on it over the last 200+ years, and by whom.
May 24, 201412 yr Greetings Mike, That's a sweet find.. I love old anvils.. Like Josh says " IF IT COULD ONLY TALK ".. I would like to be able to trace its journey... As to the pipe jammed in the hardie hole I would drill it out larger until the wall thickness is thin and than with a small drift it would collapse and come out.. Have fun Forge on and make beautiful things Jim
May 27, 201412 yr Oh yah that's an oldie just look at those stubby little feet on it! Probably not a steeled top on the horn but a badish weld in the merchant bar wrought iron it was made from. I totally envy you that one!
