eseemann Posted May 8, 2014 Share Posted May 8, 2014 Thanks to Frosty I think I am getting my "T" burner working. I need to get a ball valve in place and close off the front and back of the fire box. The photos are show a (I think) 1" pipe, .03" or .035" mig tip at about 10 psi. thanks for all the help. Quote Link to comment Share on other sites More sharing options...
eseemann Posted May 8, 2014 Author Share Posted May 8, 2014 Now some night time photos Quote Link to comment Share on other sites More sharing options...
Herb Upham Posted May 8, 2014 Share Posted May 8, 2014 I recommend you get a copy of Michael Porter's book "Gas Burners for Forges, Furnaces and Kilns", it has losts of great advice on forge construction as well as burners. Quote Link to comment Share on other sites More sharing options...
eseemann Posted May 9, 2014 Author Share Posted May 9, 2014 Herb, I will look it up, thanks. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 9, 2014 Share Posted May 9, 2014 The flame looks nice and tight speaking to good alignment down the tube. The air fuel ratio looks to be just a bit rich about where you want it to prevent scaling in the forge. The pics look to be well before the forge comes up to heat, how hot does it get? What does it sound like? You getting a decent fuel air ratio in a 1" tube with a 0.030" or 0.035" jets is beginning to convince me the jet diameter isn't as critical as I thought. One of the guys up here builds successful 3/4" T burners using 0.045" jets. My experience says you two should swap jets but both of your burners run pretty darned well. I guess all I can really say is well done. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
eseemann Posted May 9, 2014 Author Share Posted May 9, 2014 I have been told by several people that I need to up size my jets so I think I will do so. since the fire box is wide open it does not get nearly as hot as I want it to. I am going to be closing it in soon. I will take some video with sound after that to answer the question of what it sounds like. I have a good size (28" long 4" wide approx 1/4" thick) chunk of bush hog blade that will get hot enough to work but not above Orange Red so about 1500 to 1600 F. Quote Link to comment Share on other sites More sharing options...
