Glenn Posted September 23, 2007 Share Posted September 23, 2007 Ever start to stick weld and try to figure out the right settings for the material vs rod used? Miller has cleaned up the process with their welding calculator. Just input your material and the rod and they will suggest the best amp settings for your welder, the polarity and other tips. Now if your into TIG MIG and the other stuff, click here. Quote Link to comment Share on other sites More sharing options...
Ted T Posted September 23, 2007 Share Posted September 23, 2007 Glenn, Thank You! The calculators makes it as easy as falling off of a log. I flagged the sites for easy access. Be safe! Old Rusty Ted Quote Link to comment Share on other sites More sharing options...
jeremy k Posted September 23, 2007 Share Posted September 23, 2007 Glenn - LOL I couldn't find any forge welding calculators though. - JK Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted September 24, 2007 Share Posted September 24, 2007 still hard to beat the old fashioned stick rod calculator. The Diameter of the rod in Thousandts of an inch = the amperage to use. 1/8 rod = .125 inch = 125 amps as a starting place then fine tune to the job at hand. Quote Link to comment Share on other sites More sharing options...
