Trilliumforge Posted December 21, 2013 Share Posted December 21, 2013 Hi folks, I'm thinking of making a firepot for my portable forge, and I was hoping for some advice. I've seen some for sale that look good, but which are a bit too heavy for my portable unit. I'd like to fabricate something, but I'm wondering about thickness. How thin can the walls of my fire pot be? Could I make it out of 1/4" plate? 3/8" plate? I really want to keep the weight down, but I don't want it to burn through on me either. Any suggestions? Quote Link to comment Share on other sites More sharing options...
DSW Posted December 21, 2013 Share Posted December 21, 2013 Here's how I fabricated mine. '?do=embed' frameborder='0' data-embedContent>> It's made out of 1/2", but 1/4" would have worked if I wanted less weight and understood it would need replacing much sooner. I was tempted to do it out of 3/8", but the 1/2" I picked up wasn't that much more, so I opted to do it once and not have to worry about doing it again soon. Quote Link to comment Share on other sites More sharing options...
Trip Posted December 21, 2013 Share Posted December 21, 2013 I've seen a fire pot made out of 1/4" plate, but it didn't last long. I use 1/2" on all my fire pots, and they haven't shown any ware and tare. Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 21, 2013 Share Posted December 21, 2013 IN MY EXPERIENCE, a small 1/4-inch wall firepot will hold up for several years of moderate use. I used mine outside, with no shelter, with green coal and coke for 2.5-3 years exclusively, and it was still serviceable at the end of that time. On the flip side, an acquaintance of mine is reporting that his coke is turning the outside of his 5/8-inch plate firepot, a cherry red color. My suggestion is, if you have the material and you are typically going to only work lighter stock (under 3/4-inch square,) go for it. It will give you some service at least! 5/8 and 3/4 plate are wonderful for firepots, but are heavy. We don't live in an ideal world, so go with the lighter 1/4-inch material. You'll be fine! Quote Link to comment Share on other sites More sharing options...
Crazy Ivan Posted December 21, 2013 Share Posted December 21, 2013 I use an LP forge, but from what I have read, I think if you line your fire pot with clay, you will get more years out of it. I'm sure there are some good threads on here about what type/how to make your own mix of clay to do this. Good luck! -Crazy Ivan Quote Link to comment Share on other sites More sharing options...
Trilliumforge Posted December 21, 2013 Author Share Posted December 21, 2013 One of the big reasons I want to make a new firepot is to have one with a clinker breaker. Any advice on making a clinker breaker from scratch? Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 21, 2013 Share Posted December 21, 2013 Since you really want to keep the weight down, use 1/4 inch plate and make two of them. When the first one wears out in time, just remember where you put the spare and swap them out. (grin) Quote Link to comment Share on other sites More sharing options...
Backwoods Blacksmith Posted December 22, 2013 Share Posted December 22, 2013 Check out David Einhorn Civil War Blacksmith. He has a really neat set up and it is a side draft. No clinker breaker needed and it would work well with charcoal. Quote Link to comment Share on other sites More sharing options...
DSW Posted December 22, 2013 Share Posted December 22, 2013 There's a clinker breaker shown in my thread above. In it's current form I welded up 3 pieces of 1 1/2" x 4" 3/8" thick IIRC in a triangle around the rod. I figured out the sizes based on what side dimension gave me the closest to 1/2" in the center when I had it all welded up. I may have had to drop down to 1 1/4" vs 1 1/2", it's been awhile. So far so good. If I did this again, I might look at either buying one of the cast iron ones from Centaur forge, or possibly one of the iron balls from King metals and reworking that. When I did my firepot I ended up wit ha rectangular bottom vs the square one I originally was shooting for. For that reason I simply made my own clinker breaker. Quote Link to comment Share on other sites More sharing options...
