Firegirl Posted August 23, 2007 Share Posted August 23, 2007 Other than Silverflow...does anyone know of a brazing rod for copper that stays copper in color? I do a lot of boxes and need to keep my corners in cahoots with the rest of the piece. Your ideas are greatly appreciated :) Quote Link to comment Share on other sites More sharing options...
ladysmith Posted August 23, 2007 Share Posted August 23, 2007 You want PhosCopper (or phos-copper) rods. The color match is excellent. Also if you flux a copper rod, you can braze copper to copper. Quote Link to comment Share on other sites More sharing options...
ladysmith Posted August 24, 2007 Share Posted August 24, 2007 Firegirl, Here is a bit more information on brazing with pure copper: flash youtube videos (look for Brazing with Copper Wire) I have some of George Goehl's video's. They are excellent. I'd recommend them to anyone interested in basic artistic metal working...especially copper. Also check out his forum section for more tips, resources, etc. I'd be interested in seeing some of your boxes. Hope that helps, Pam Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 24, 2007 Share Posted August 24, 2007 There is some information of Brazing at Soldering / Brazing / Welding Quote Link to comment Share on other sites More sharing options...
haw_thrn Posted August 26, 2007 Share Posted August 26, 2007 you can also get copper rods Quote Link to comment Share on other sites More sharing options...
Firegirl Posted August 27, 2007 Author Share Posted August 27, 2007 THANK YOU!!!!!! That was incredibly helpful!....I took some pictures of the finished box Ladysmith, and I will post it here as soon as I get them developed. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted August 27, 2007 Share Posted August 27, 2007 FG - If you have some extra copper matl's - - sometimes I cut narrow strips from them to use as filler, If I do not have any boughten rods - then the color match will be right on. Just another possibility for you to use, course I do a lot of tig welding so this works well for me. - JK Quote Link to comment Share on other sites More sharing options...
ladysmith Posted August 27, 2007 Share Posted August 27, 2007 Jeremy, Are you talking about using the narrow scrap strips when brazing with an oxyacetylene torch? If so, do you use flux? Any special type? PamFG - If you have some extra copper matl's - - sometimes I cut narrow strips from them to use as filler, If I do not have any boughten rods - then the color match will be right on. Just another possibility for you to use, course I do a lot of tig welding so this works well for me. - JK Quote Link to comment Share on other sites More sharing options...
jeremy k Posted August 27, 2007 Share Posted August 27, 2007 Pam - I've only done this with the tig process - only because I have it available whenever needed - for me having the tig machine makes the torch almost obsolete, besides preheating and such. On a rare occasion one runs out of filler at the wrong time ( with only about a half inch to go) so cutting a small strip to use as a filler works in a pinch. Color match wise with copper this would be the best thing to do although I have cut slivers off a plate of aluminum for rods to finish a job when I've ran out of filler rods at the wrong time. I use the phos-copper any time I need to weld copper though (tig process). When polished the Phos-copper rod gives a very good color match. Otherwise while it patinas by itself the weld will show a little - but under a mirror polish you cannot tell where the weld is. I'll have to try to find a picture of a copper table I made from 4" copper water pipe - the whole table frame was polished to a mirror finish - not sure if I have that on digital though - it's been a long time. - JK Quote Link to comment Share on other sites More sharing options...
