Walnut Square Iron Posted May 6, 2013 Posted May 6, 2013 I am a new member here and I don't have the book yet. I have a HB that I got from my dad several years ago. I have used it over the years working brass and copper sheets and roughing up hinges for woodworking projects. I finally brought it outside to the forge and worked some pieces on it a few times. It felt good to put it back into service. While I was doing some research on it, i ended up on IFI and found a lot of good info. I believe another member here has a HB with a serial number a few digits off from mine. 30" long x 12" tall Serial # 201236 There is some wording in the middle under Hay Budden that I can't quite make out. Maybe a bad strike. 1" hardie and two 1/2" pritchell holes I haven't weighed it, but it is at the outward range of my lifting capabilities. I don't plan on taking it off the block again, let me put it that way. Thank you for any info. Quote
Frosty Posted May 6, 2013 Posted May 6, 2013 She's a beauty, good score! That last pic of the two prichel holes makes it look like someone really surprised her. <BFG> Frosty The Lucky. Quote
Walnut Square Iron Posted May 6, 2013 Author Posted May 6, 2013 Much appreciated. AIA is going to be on my birthday list in the coming weeks. Mr. Postman says 1913. Quote
