justin chenault Posted April 8, 2013 Posted April 8, 2013 I just picked up a helve hammer this weekend and I am looking for a ID on it. I have been looking everywhere I can online and I cant find anything on it as there are no MFG marks anywhere on it. Uploaded with ImageShack.us Any help would be great as I would like to come up with some kind of history on this hammer as I am trying to get it going. Thanks justin Quote
macbruce Posted April 8, 2013 Posted April 8, 2013 Hi Justin, There's nothing like it in ''Pounding Out The Profits''. What's your location? Quote
Madmike Posted April 8, 2013 Posted April 8, 2013 Lovely ;) Never seen one like that either :rolleyes: Quote
jeremy k Posted April 8, 2013 Posted April 8, 2013 Jenkins power hammer - Page 241 in "Pounding out the profits" Quote
Tommy Traylor Posted April 8, 2013 Posted April 8, 2013 Jenkins & Lingle. I have one too. Tried to get a photo but it is buried in my dark barn. Quote
justin chenault Posted April 9, 2013 Author Posted April 9, 2013 Sorry about not responding sooner Macbruce- I am in central Ohio jeremy k & tommy traylor - thanks for the info i now have something to base my search on now I just have to get the foundation poured for it and get it powered up. Everything seems to move freely the rubbers are in decent shapeI just need to get the motor hooked up and get a flat belt drive pulley for it and we are in buisness. anyone know where a flat belt pulley for an electric motor can be bought from Quote
Will. K. Posted April 9, 2013 Posted April 9, 2013 I've heard of these sources but never used either: http://hitnmiss.com/25a.html#pulley http://www.paperpulleys.com/ And of course there is always ebay. If you need belting and can use the composite rubber belting Tractor Supply stores are clearancing out their "by the foot" rubber baler belting. According to my local store the reason for the clearance sale is that they are going to pre-cut lengths only. Quote
Jim Coke Posted April 9, 2013 Posted April 9, 2013 Greetings Justin, You best figure out the rpm and hp of the motor you are going to use.... I have an old Hawkeye that is a lawn ornament now that I was going to run in my line shaft shop for show and tell... To dangerous for the kids and folks so I aborted... Typically these old fellows ran of a line shaft that only ran about 250 rpms... I suggest you get ahold of Tom from above he says he has one on the line.... If you must use a small diameter pulley on your motor I suggest you use a paper drive off the pto from older tractors ... ( International ) Keep it thumpin.... Jim Quote
Francis Trez Cole Posted April 13, 2013 Posted April 13, 2013 I by my flat belts from Mc Master Carr Quote
justin chenault Posted April 25, 2013 Author Posted April 25, 2013 so I just scored a 5 horsepower 1725 rpm motor for $300 so I'm hoping I can run a 2 inch pulley on the shaft to the 12 inch pulley on the hammer and be okay that should put me around 280ish rpm at the hammer. for you hammer guys does that sound like it'll work out Quote
Jim Coke Posted April 25, 2013 Posted April 25, 2013 Greetings Justin, I think you will find 5hp is fine BUTTTT.. A 2in flat belt drive pulley 3in wide will slip under power.... I suggest you set up a jack shaft style set up.. ( surface area of the belt contact ) Good Luck Jim Quote
justin chenault Posted April 26, 2013 Author Posted April 26, 2013 The machine has a 5" wide flat belt pulley and is set up to run off a line shaft with a slack belt and tensioner so it is intended to have some slippage. Are you saying it would have to much slippage? I was planning on setting the motor up overhead in the rafters and running the belt down to the hammer I was hoping to avoid the jack shaft setup if possible but if not I guess I will use one. Quote
Jim Coke Posted April 26, 2013 Posted April 26, 2013 Greetings Justin, I feel the amount of belt surface area on a 2in pulley is not enough for initial start of the hammer . Ever wonder why many heavy load machines have multiple belts and larger drive pulleys... I think you would loose a lot of control on start up and overall control.. I have a line shaft shop and have made that mistake.. It takes a lot of energy to get things moving... More than likely what would happen is you would push the tension pedal hard attempting to get started and the hammer would go faster than you wanted... I have a lot of pulleys and have never seen a 2in 5in wide drive pulley with a 3/4 shaft size.. I hope this helps . Maybe others will tune in with advice... Good luck Jim Quote
justin chenault Posted April 27, 2013 Author Posted April 27, 2013 Thanks for the info Jim I was worried that the 2" would be too small. Well its back to the drawing board then. So what size drive pulley would you reccomend for this size hammer? The ram weighs roughly 75lbs and has a crank pulley 12" diameter. Quote
macbruce Posted April 27, 2013 Posted April 27, 2013 Why not use a v belt set up from the motor to the drive wheel? This works fine on many a Little Giant.... Quote
Jim Coke Posted April 27, 2013 Posted April 27, 2013 Greetings again Justin, I don't think a lot of people understand that the only control that you have over your hammer is the tension on the idler... You have no clutch like LG or others... Now we get down to what I would do... See that you said you can mount it overhead.... I would mount your motor to twin belt reducing v pulleys on a jack shaft with at least a 100 pound flywheel and than to at least a 8 inch final drive pulley to your hammer... You can figure the ratios.. The reason I would do it that way is to have inertia for initial starts and overall control... Old time line shafts have many pulleys on the shaft and have the inertia required... That's just my way to skin this cat.. Let me know your progress... I wish you well Jim Quote
marcusb Posted April 30, 2013 Posted April 30, 2013 Hey, that hammer looks familiar Pick it up in Holgate? Quote
