June 26, 200719 yr they can be used for all sorts of things, i use them for setup blocks, its nice because they are exactly 1 inch by 2 inch by 3 inches (unless they have been messed with) you can use them to block parts up a certain amount to machine surfaces, the ones with tapped holes come in handy to, you can clamp them in a vise and use the screw holes to bolt parts to for surface grinding and machining, drilling and tapping its endless the uses in a machine shop thats the best i can explain it Ron Smith
July 13, 200719 yr Good explanation Ron. They are ground square and parallel. so along with the dimensions given by Ron they can be used in a multitude of configerations in an accurate fashion. Hope that helps, Jay
