TJ Smith Posted January 15, 2013 Share Posted January 15, 2013 "I bought a 150# jet anvil brand new paid around $250. It is supposed to be cast steel?? Dropped a 1 inch ball bearing from 1 foot it bounced back about 8 inches. When you hit it with a hammer the hammer does recoil. It will be a long time before I realize it doesn't work as good as it should. Watch out for used anvils: a lot of them have been through a fire and won't bounce a bearing at all" Take Care TJ I posted this back in o2 wondering why a cast iron anvil isn't any good. People say good for a boat anchor or a door stop. Does anybody know why? or are we just like sheep and follow the flock? BAAAAAAAAAAAAA Tj Quote Link to comment Share on other sites More sharing options...
jcornell Posted January 15, 2013 Share Posted January 15, 2013 Cast iron or cast steel? The ASOs at Harbor Freight are cast iron - although it's better than nothing, I think most smiths agree that they aren't worth the trouble. A cast steel anvil, however, is nothing to sneeze at. Anyone who wants to give me a Rhino or Nimba anvil (both cast steel), drop me a line. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted January 15, 2013 Share Posted January 15, 2013 They work, but when you get on a good hard anvil the differance is night and day. I worked on a RR track anvil for years, it had about a 50% rebound at best. Working on a 200lb Fisher now with a 90% rebound. Wow, it really moves more metal. Quote Link to comment Share on other sites More sharing options...
macbruce Posted January 15, 2013 Share Posted January 15, 2013 Take a ball peen hammer and do a light/medium hit on the face of the anvil with the ball.....If it leaves a dent you'll know why.......;-) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 15, 2013 Share Posted January 15, 2013 Cast iron is fragile---it breaks fairly easily Cast iron is generally *soft* it will dent under red hot steel being worked on it. Do these properties sound like an Anvil to you? Quote Link to comment Share on other sites More sharing options...
philip in china Posted January 17, 2013 Share Posted January 17, 2013 Cast iron or cast steel? The ASOs at Harbor Freight are cast iron - although it's better than nothing, I think most smiths agree that they aren't worth the trouble. A cast steel anvil, however, is nothing to sneeze at. Anyone who wants to give me a Rhino or Nimba anvil (both cast steel), drop me a line. Hear hear. A couple of good brands mentioned there. Virtually all modern anvils are cast- but they are cast steel and the difference is chalk and cheese. I have a couple of Chinese made cast iron anvils here which I use for some purposes but not for forging on. Cast iron deforms so much as you are hammering it absorbs a lot of the energy of the hammer. You will wear yourself out working on one. You would do much better just with a big piece of scrap steel. Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted January 17, 2013 Share Posted January 17, 2013 Vintage forged anvils are just way cooler B) Quote Link to comment Share on other sites More sharing options...
SReynolds Posted January 17, 2013 Share Posted January 17, 2013 I have a known cast steel anvil and it dents when/if you hit it with a ball peen. It has this real nice/loud ring to it too when you simply tap it. It is in great shape as it obviously wasn't used for anything.....untill I bought it used from an anvil collector. Quote Link to comment Share on other sites More sharing options...
tomhw Posted January 17, 2013 Share Posted January 17, 2013 You are more important than your anvil. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 17, 2013 Share Posted January 17, 2013 Note I mentioned that I had a cast iron anvil dent *under* the workpiece not hitting the anvil with a hardened hammer! Even very soft real wrought iron worked when forging extremely soft wrought iron at proper forging temps without a similar issue. Quote Link to comment Share on other sites More sharing options...
