brian robertson Posted November 12, 2012 Share Posted November 12, 2012 Is handling weight the main reason for a 2 piece hammer? what are ther other advantages? Just trying to wrap my head around the concept. Quote Link to comment Share on other sites More sharing options...
macbruce Posted November 12, 2012 Share Posted November 12, 2012 I reckon once hammers get over a certian size it makes more sense to do them in two castings rather than one especially when the correct anvil tup ratio can only be accomplished by setting the anvil beloiw grade. Otherwise the anvil would be too tall........... Quote Link to comment Share on other sites More sharing options...
dkunkler Posted November 12, 2012 Share Posted November 12, 2012 There has been some discussion on that subject here.http://www.iforgeiron.com/topic/29858-1-piece-vs-2-piece/page__hl__%2Bpiece+%2Bhammer Quote Link to comment Share on other sites More sharing options...
knots Posted November 12, 2012 Share Posted November 12, 2012 Another reason is that power hammers with frames fabricated from steel plate can use cast steel or iron anvils on a common massive foundation. My KO isn't that big a hammer and has a cast anvil loosely affixed to the steel frame both mounted on a common foundation. The combined weight of hammer and anvil is probably around a thousand pounds. Not all that heavy until you add the weight of the common foundation required. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted November 12, 2012 Share Posted November 12, 2012 A single piece hammer generally has a flat base. With a two piece hammer, the bottom of the anvil is generally lower than the base of the hammer frame. The anvil to ram ratio is generally greater (heavier anvil) with a two piece hammer, making the hammer more efficient. Quote Link to comment Share on other sites More sharing options...
brian robertson Posted November 14, 2012 Author Share Posted November 14, 2012 thanks for the info Quote Link to comment Share on other sites More sharing options...
