Todays challenge - Swan's Neck hardie
Tubbe
Hi,
Today I set up a small challenge for my self, as I (we) often do, to make a swan's neck hardie tool. Sooner or later I want to try out some more serious scroll work and thought a tool like this could be helpful.
Started off with about 7" of 1" square stock (mild steel), made a slight upset about 2" in from the end and forged a shoulder and the hardie post to fit. Then it was time for the swage block and some bashing with the sledge. I worked it all down to a block about 1,5"x1,5"x2,5" , then made the taper and finally bent it to shape. It's not perfect but I think it will do the work.
Here it is. I may have to grind the tip a bit sharper, what do you think? A sharper edge means a weaker tool, but I doubt one actually forge on the tool, rather bend and form, right?
Back to drawing some scrolls....
Cheers
Awesome job. Did you use a Flatter to smooth it out, or just hammer control? Definitely some fine work!
Thanks! I do own a small trip hammer which does a fine job on square surfaces. For tapers I use a round-back flatter (I think thats the right name?), and that works pretty good as well. One has to be careful to align the work right in the hammer though.
  • 3 weeks later...
