wolfshieldrx Posted October 1, 2012 Share Posted October 1, 2012 Forge-welded ring is 4 inches in diameter. All parts made fron 1/4 x 1/2 inch stock. Finish is beeswax rubbed on while hot. Thanks for lookin...bart Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted October 1, 2012 Share Posted October 1, 2012 Very nice bart. I was just asked about making some yesterday. I like the hearts for the legs. What happens to the wax when a hot pan is set on it? Mark <>< Quote Link to comment Share on other sites More sharing options...
Drewed Posted October 1, 2012 Share Posted October 1, 2012 I like that. Do you have a side view? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 1, 2012 Share Posted October 1, 2012 As that sort of trivet is used over hot coals to allow heating of pans without legs I would assume the wax gets fried off long before a hot pan contacts it. If it's used only decoratively then it's not an issue. (As I'm making renaissance kitchen "tooling" I've made several of these based on the Opera of Bartolomeo Scappi, 1570---and need to make more as I had a request for smaller shorter ones recently now that I have the ones done for the 10-15 gallon pots done. I tend to rivet the legs on and then forge weld them in place smoothing off the top of the trivet in the process.) Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted October 1, 2012 Author Share Posted October 1, 2012 Thanks guys. I apply the wax on these at a high black heat. I would say burnt on instead of melted on. Plus I brush really well with a wire brush durung and after application. I made a couple larger trivets for my wife a year ago and have had no problems with hot pots. Like the idea of forge welding the legs; may have to try that. Thanks for looking...bart Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 1, 2012 Share Posted October 1, 2012 I've had real fun forge welding the legs on the ones for the big pots as they are long enough I have to stick the leg up the forge chimney to get the join in the fire at the correct spot and then unwinding it from the forge and getting it to an anvil fast enough to weld...Of course the heavier stock helps. I generally test out the big ones by standing on them---250 pounds. The other typical trivet I make is made with 3 sections of strap stock where I weld the ends of two pieces together to make a leg/foot and then weld the third piece to the other end of one and then bend everything together and weld the last two ends into a leg/foot and get a 3 legged trivet Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted October 2, 2012 Author Share Posted October 2, 2012 I've had real fun forge welding the legs on the ones for the big pots as they are long enough I have to stick the leg up the forge chimney to get the join in the fire at the correct spot and then unwinding it from the forge and getting it to an anvil fast enough to weld...Of course the heavier stock helps. I generally test out the big ones by standing on them---250 pounds. The other typical trivet I make is made with 3 sections of strap stock where I weld the ends of two pieces together to make a leg/foot and then weld the third piece to the other end of one and then bend everything together and weld the last two ends into a leg/foot and get a 3 legged trivet Been wanting to try one of those as my forge-welding skills improve. Thanks for the input! bart Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted October 3, 2012 Author Share Posted October 3, 2012 Here's a side view: Thanks for looking...bart Quote Link to comment Share on other sites More sharing options...
Camero68 Posted October 3, 2012 Share Posted October 3, 2012 Greatly done. Special attention to the heart legs, too. Quote Link to comment Share on other sites More sharing options...
Camero68 Posted October 3, 2012 Share Posted October 3, 2012 This work symbolizes beauty and strength. Quote Link to comment Share on other sites More sharing options...
