ThomasPowers Posted September 21, 2012 Share Posted September 21, 2012 There have been reports of Spray-on sunscreen catching on fire even after appreciable waits after application. Latest I've seen was of a lady who waited 5 minutes before she started to weld and her arm caught on fire. http://www.wavy.com/dpp/news/local_news/chesapeake/spray-on-sun-screen-burns-womans-arm?hpt=us_bn8 Sounds like a danger smiths might run as well. Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted September 21, 2012 Share Posted September 21, 2012 Thanks Thomas. There are so many things out there that can hurt us I appreciate the heads up. I imagine we should treat aerosol insect repellant the same way. Hate to spray down to ward off pesky skeeters only to combust. Again, thanks. Mark <>< Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 22, 2012 Share Posted September 22, 2012 I like the ambiguious warnings in the article. I will have to check, but most of the sunscreen lables I have read recommend 20 minutes before going outside after application. I wonder if that is adequate for the flammability to go down. Those aerosol sunscreens sure are quick and convinient to use most of the time. I have been using only aerosol sunscreen for the last few years. Phil Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 24, 2012 Author Share Posted September 24, 2012 I tend to use wool felt and cotton as sun screens when I can't use wood or steel. Quote Link to comment Share on other sites More sharing options...
ptree Posted October 10, 2012 Share Posted October 10, 2012 Be aware that aside from the materials being propelled from aerosol cans, since the EPA ruled out Freon as a propellent, the common propellant is a mix of Propane, butane and Iso-Butane. You can have an aerosol spray can of water and most likely it is a flammable spray exiting the nozzle. Quote Link to comment Share on other sites More sharing options...
