woodtick Posted May 3, 2007 Share Posted May 3, 2007 I've finally made a guillotine tool, I'm pretty excited about it because it's my first one and I made it myself. I want to make a set of dies for fullering candle holders from 1 inch pipe but I'm not sure of the shape. (Heck I don't even know how to ask the question properly) Link to comment Share on other sites More sharing options...
Glenn Posted May 3, 2007 Share Posted May 3, 2007 BP0065 Guillotine Anvil Tool shows several different combinations of dies Link to comment Share on other sites More sharing options...
Jeff Mack Posted May 3, 2007 Share Posted May 3, 2007 Woodtick, what holds the back of the top die in place? And, thanks for posting pics. A guillotine tool is on my project list. Jeff Link to comment Share on other sites More sharing options...
skunkriv Posted May 3, 2007 Share Posted May 3, 2007 Nice job on the guillotine. For candle cups the dies I use are kind of a diamond shape laying on its side (when you are looking at both dies, closed). I size the vertical portion of the diamond so that when the outside (unaltered) edges of the die come together they act as a stop leaving the final dimension of the fullered portion the size I want. Round all the edges of the dies up real good with a belt grinder or angle grinder. Link to comment Share on other sites More sharing options...
evfreek Posted May 4, 2007 Share Posted May 4, 2007 Hi woodtick. Those dies that are in the picture look like butcher or tenon dies and would not be appropriate. I just use a spring fuller for my tapered candle cups and it turned out fine. Might work better with a little radiused diamond hole. Another project . This is where the guillotine tool shines, which by the way, you have a nice example of. My spring fuller has about a 3/16" for 3/8" wrapping rod around the candle cup. Link to comment Share on other sites More sharing options...
woodtick Posted May 4, 2007 Author Share Posted May 4, 2007 Jeff, the top die is held in place with a piece of plate steel(scrap from the side material) welded in place. Link to comment Share on other sites More sharing options...
Please sign in to comment
