Single-brick forge burner efficiency
Bowmaod
After cracking piece after piece of steel from heating it in the dirty coal I bought, I decided to make the move to other fuels. I have a propane burner I pulled together about a year ago, but it's actually more of a flamethrower... it doesn't work very well. Anyway, I'm thinking about a single-brick or coffee-can propane forge to run alongside my charcoal forge.
I saw that single-brick forges generally run on small plumbers torches. How well do these torches work as forge burners? Are they actually a valid way to run a forge, or are they more of a novelty? I'm especially concerned about cost, because I can make a standard propane burner in a day with a little amount of work, but a lot of the stuff I do is small, and I hope to get into bladesmithing eventually, so I'd rather use charcoal for big projects and a tiny propane forge for little things.
Thanks.
I started with a big plumbers torch in insulating bricks. and you will get enough heat to move metal, but no where near close enough for a weld.
they are a waste of time in my opinion.
Frosty has a design floating around that is easy and cheap (under $15) each. http://www.iforgeiron.com/topic/12176-i-pumped-frosty-for-information-and-made-this/ for a whole link on the topic.
There are others as well
I have made more than a dozen of them, and they are great, cheap and very hot.
I use mine as much as possible because the efficiency. My big 4 burner get little use these days.
Thanks! That's perfect. I was looking for the most efficient burner, and this looks like it will do well (and save me the trouble of making a ton of charcoal). The other propane burners I found were such a hassle to make...
I used a single soft firebrick and plumbing torch forge to make nails and hot forge silver as I could do it inside my drafty old (stone walled) basement in Ohio during the winters.
I found that it was quite acceptable as long as you were not in a big hurry. Getting an adapter to run a small torch off a BBQ tank brings the fuel cost way down!
I may see if can get my hands on a plumbers torch. It seems like a good thing to have.
One final question (I think) - what is the average price I can expect for running a bucket-sized propane forge? I read somewhere that a 20# tank will last around 8 hours of forging. Is that a good rule of thumb for propane?
I don't understand this question.
Depends.... on the size of the gas orifice, on the pressure (PSI) of the gas, whether blown or naturally aspirated, on your ability to judge heat and/or forge atmosphere, how the forge is constructed/interior forge chamber in cubic inches/insulated/size of the openings/ceramic fiber coating/use of ITC-100, size of stock, welding or forging/etc.. I run two half inch Michael Porter style burners in a freon tank forge and get about 15 hours from a 20# bottle of gas. I light it at 5 psi and reduce to about 3psi once the forge is 'at temp'. Your mileage will vary. I forge knifeblades and don't weld.
Oh, sorry. I was just asking how much money I would expect to spend on propane. I did some basic calculations and got around 10 hours per 20# tank at ~$17 per refill, which gives $1.70 per hour of burner use. Not too bad, but still more expensive than making my own charcoal, which is expected.
Thanks, everyone.
