j.w.s. Posted April 16, 2012 Share Posted April 16, 2012 So I have this Atlas cylinder I'd like to use in an upcoming build. I'm sure it has class 1 seals which means it will work fine with air or hydraulic fluids. I took the caps off and it operates easily with just my airgun in the ports. The etch on the side says it's an H025-PB2-0100-4NCSV 14.000. From what I'm able to gather it's a 2.5" bore, 1 inch rod with a 14" throw, however I'm unable to find the correct port bushing for it. There was a 0.75 bolt plugginh onr port, however I know it's not a 10 thread. I tried a 1/2" to 3/8" bushing at TSC today and it wouldn't thread in. Just wondering if anyone might have an idea what size I should be looking for. Unfortunately the Parker/Atlas site is not loading for me and what information I was able to pull off of a pdf was just a little jumbled around since it was for every possible configuration of this heavy duty cylinder series. I'll attach a pic. Thanks! -J Quote Link to comment Share on other sites More sharing options...
Dogsoldat Posted April 16, 2012 Share Posted April 16, 2012 I think you will be looking for an 'ORB' fitting for that now whether it's metric or standard is the only question.http://www.goodvibesracing.com/orb_fittings.htm this is what they look like. Just the first goole link I pulled up. hope it helps Quote Link to comment Share on other sites More sharing options...
j.w.s. Posted April 17, 2012 Author Share Posted April 17, 2012 Found them at a local hydraulic store, thank you. now I just need to figure out how to up my rate of travel. This ram is about 2/3 the speed of my 2x8 cylinder. I'm using 3/8 tubing so maybe I should up it to something with more flow? -J Quote Link to comment Share on other sites More sharing options...
SmoothBore Posted May 30, 2012 Share Posted May 30, 2012 The key to controlling the speed of an air cylinder, ... is in controlling the EXHAUST. There are a variety of "quick exhaust" fittings that will help you with that. Quote Link to comment Share on other sites More sharing options...
