metalmaster1766 Posted March 7, 2007 Share Posted March 7, 2007 Anyone know what this is? steel pins about 1/4" in an aluminum block. thanks Ron Smith Quote Link to comment Share on other sites More sharing options...
Bear Posted March 7, 2007 Share Posted March 7, 2007 I've seen these before but dont have a clue what it is.:confused: Sean Quote Link to comment Share on other sites More sharing options...
easilyconfused Posted March 7, 2007 Share Posted March 7, 2007 Not sure what it is but it sure looks like it would give a great massage :D Quote Link to comment Share on other sites More sharing options...
IronFist Posted March 8, 2007 Share Posted March 8, 2007 I've seen something like this in a mill that I used to do contract welding in, but it may have been on a bit larger scale. It was for heat dispersal on high heat machines. Kind of like the fins on a motorcycle cylinder/ head. Other than that- couldn't tell you! Where did you find it? Quote Link to comment Share on other sites More sharing options...
Rantalin Posted March 8, 2007 Share Posted March 8, 2007 That would make sense actually. The large surface area of the steel pegs would allow for large amounts of heat transfer. Quote Link to comment Share on other sites More sharing options...
metalmaster1766 Posted March 8, 2007 Author Share Posted March 8, 2007 the pins are steel, only the block is aluminum i picked it up at the scrap yard, a good friend of mine owns a scrap yard, there were 2 of them, i took one and another friend took the other. i have seen these somewhere before too, i have seen similar things used to clean sharpening stones Ron Smith Quote Link to comment Share on other sites More sharing options...
anglesmith Posted March 9, 2007 Share Posted March 9, 2007 Ron what size is it ? If it's hand size, cleaning stones or soft morta off bricks might be on the right track? Sorta looks like a coarse wire brush! Graeme Quote Link to comment Share on other sites More sharing options...
metalmaster1766 Posted March 9, 2007 Author Share Posted March 9, 2007 The aluminum block is 3" by 5" by 1" thick, the steel pins are 2" long, I'll find a use for it, may hurt a bit for a massage. Maybe ill stand on it, might make my feet feel better after standig all day Ron Smith Quote Link to comment Share on other sites More sharing options...
