yves Posted October 30, 2011 Share Posted October 30, 2011 My vise's screw is dirty ans sounds like I'm grinding metal when I turn the handle. I'll clean it with kerosene but what do you lubricate it with? And when the minus 30 degrees hit us up here what will still turn? Thanks. Quote Link to comment Share on other sites More sharing options...
clinton Posted October 30, 2011 Share Posted October 30, 2011 I use just regular old grease in mine but it rarely gets under 50 degrees fahrenheit here Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted October 30, 2011 Share Posted October 30, 2011 Try ATF for lube after cleaning. Quote Link to comment Share on other sites More sharing options...
Brian D Posted October 30, 2011 Share Posted October 30, 2011 I like to use a dry lube that can be painted on wet and when it dries, it leaves a thick film of dry lubricant. It has worked well for me in the past. The stuff I use is made by Loctite and is called Moly Dry Film Lubricant. Some good reasons for dry lube...Not affected much by cold weather Dry does not attract dust, grit, junk Thick dry film stays in place better than grease or oil (does not squeeze out of threads) Quote Link to comment Share on other sites More sharing options...
yves Posted October 30, 2011 Author Share Posted October 30, 2011 Thanks everyone. Quote Link to comment Share on other sites More sharing options...
Moose Forge Posted November 27, 2011 Share Posted November 27, 2011 I just redid mine and I used white lithium grease from the local Home Despot. Jim Dunning Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 28, 2011 Share Posted November 28, 2011 I saw a neat mod to a columbian post vise---they have a hole in the back end of the screwbox and the owner brazed a cover for the hole and installed a Zerk in the center of it so the lube pushes crud *out* of the screwbox. As for low temp lubes, ask around at the local farm store what they advise for your area! Quote Link to comment Share on other sites More sharing options...
yves Posted November 29, 2011 Author Share Posted November 29, 2011 Again, thanks to every one.ThomasPowers, I did just that, ask around and a guy I had asked to came over that evening & lubricated the screw with some grease he says he uses all winter on his backhoe, with a smile, a few jokes on me and to "just tell him when I think I need some more". It works smooth and fine and sounds good because it does not make a sound anymore... Quote Link to comment Share on other sites More sharing options...
