D Justin Hamilton Posted October 12, 2011 Share Posted October 12, 2011 Hello to all. I have another repair related question that I wanted to throw out here, to see if my thinking is right. Recently, I bought a used post-vise on ebay. It seems to be in good used shape, except for the leg. It is ever-so-slightly bent at the bottom. My guess would be that it is out 5 degrees or less. I am thinking that I should secure it, try to heat the bend with a torch, and then use a "cheater bar" to try and true it up, but I wanted to get some more experienced advice before I went and did something that I will regret. I will try and get a picture posted on here tomorrow if I need to. Thanks in advance for the help. Link to comment Share on other sites More sharing options...
Brasilikilt Posted October 12, 2011 Share Posted October 12, 2011 Your plan sounds fine to me, but given the fact that a lot of these vises are made or fairly soft wrought iron you may not even need to heat it. I bought a pretty rough vise off of Ebay a couple years back which had similar issues with the leg. I figured that since the leg was likely bent while cold, It can be also straightened while cold. All I had to do was disassemble the vise and set the leg on the table of my anvil and rotate the vise leg while giving it a few good whacks with a hammer. It straightened right up and have had no problems with 2 years of use. This being said, my vise is a fairly light 40 (ish) pounder with 4" jaws. On heavier vises with a thicker leg, your idea would probably work more efficiently :-) Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 12, 2011 Share Posted October 12, 2011 I generally do this sort of thing cold with my screw press. The worst that can happen is that it fails and I get to forge weld it back together! Link to comment Share on other sites More sharing options...
clinton Posted October 16, 2011 Share Posted October 16, 2011 Have someone hold it on top of your anvil and use a sledge hammer, a couple of good whacks should do it Link to comment Share on other sites More sharing options...
D Justin Hamilton Posted October 17, 2011 Author Share Posted October 17, 2011 Thanks for the response. That, I will try. Link to comment Share on other sites More sharing options...
Please sign in to comment
