trinculo Posted October 5, 2011 Share Posted October 5, 2011 http://aimkiln.com/aimcrucible1411c.htm So I just acquired one of these (scroll to model 1715C without the crucible). How will this work as a heat treating oven? It has a digital control with a couple of ramps. It is alleged to work. Didn't test it, but the new elements are around $40. At this point my HT has been very unscientific using scrap yard springs for making my tooling, heating in my NC tool propane forge and quenching in water or veg oil, mostly hardies and power hammer texturing tooling. I have started making some blades, but have yet to heat treat any yet. After most of a year blacksmithing, i'm just learning how much there is I don't even have a clue about. My continuing gratitude for those sharing their knowledge here. dw Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 6, 2011 Share Posted October 6, 2011 Should work fine. Put some charcoal in the bottom to reduce decarb and scale. Quote Link to comment Share on other sites More sharing options...
trinculo Posted October 7, 2011 Author Share Posted October 7, 2011 What kind of charcoal and how much? Should I out it around the metal being heated? thanks, dw Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 7, 2011 Share Posted October 7, 2011 Just as long as the charcoal is in the chamber it will consume the oxygen. Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted October 27, 2011 Share Posted October 27, 2011 Should you put charcoal in any oven that you use for tempering? thanks. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 28, 2011 Share Posted October 28, 2011 If you get the fancy stainless steel foil bags you put the charcoal in the bag. Phil Quote Link to comment Share on other sites More sharing options...
thingmaker3 Posted October 28, 2011 Share Posted October 28, 2011 Charcoal or other oxygen getter is needed at the higher temperatures. If it is not hot enough for scale to form or decarburisation to be any worry, then no oxygen getter is required. Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted October 28, 2011 Share Posted October 28, 2011 thanks , what temp are we talking here? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 28, 2011 Share Posted October 28, 2011 Protection from oxygen for anything hotter than dull red (1000F) would be good, but scale starts forming at a lower temperature than that (tempering colors are very very thin layers of oxide, fire scale is much, much much thicker, and yes, FeO2(blue/black) vs Fe2O3(red)). Oven tempering at household oven temperatures should not be a problem, unless you are preserving some engravings or other polished features that were made before heat treat. If engraved then charcoal and stainless foil can be used in tempering to reduce the need for heavy polishing because of tempering colors. Of course if you plan to grind heavily then you don't need to worry about scale as much. Phil Quote Link to comment Share on other sites More sharing options...
