jfifft Posted July 27, 2011 Share Posted July 27, 2011 I hope this is the correct area to post this. I have some 2" x 72" sanding and buffing belts that have never been used and I noticed the seams are breaking. Some are the expensive scotchbrite type (not 3M) type. It would seem (no pun) one could re tape them or something. Has anyone done this before or know what to use? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted July 27, 2011 Share Posted July 27, 2011 If you have belts that are coming apart at the seams, Don't try to use them, unless you are into selfmutilation. Those belts will eat flesh faster than you can react. Cut them apart and use them for sanding paper or like emory cloth. Don't EVER put them on the machine and take the chance!! :wacko: Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted July 27, 2011 Share Posted July 27, 2011 If you have belts that are coming apart at the seams, Don't try to use them, unless you are into selfmutilation. Those belts will eat flesh faster than you can react. Cut them apart and use them for sanding paper or like emory cloth. Don't EVER put them on the machine and take the chance!! I'll second that. I know from experience that a belt coming apart at the joint can really hurt! (Don't ask)! Quote Link to comment Share on other sites More sharing options...
HWHII Posted July 28, 2011 Share Posted July 28, 2011 I use my broken belts for hand sanding. Just cut them to size with a pair of sizzors. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 28, 2011 Share Posted July 28, 2011 I'll second that. I know from experience that a belt coming apart at the joint can really hurt! (Don't ask)! a worn belt letting go and slapping flesh doesn't feel good either. Phil Quote Link to comment Share on other sites More sharing options...
jfifft Posted July 28, 2011 Author Share Posted July 28, 2011 Thanks for the replies and good advice everyone! Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 28, 2011 Share Posted July 28, 2011 Not using a belt that's coming apart made it to my NEVER do that again, short list first try. Are they coming apart before you mount them or shortly after you try running them? If they're coming apart after you try using them you may be mounting them backwards, the seams don't like that and will slap you silly for it. Most brands have an arrow on the back for that reason. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
jfifft Posted July 29, 2011 Author Share Posted July 29, 2011 Thanks Frosty, They come apart after I use them. I never knew there was a right way to mount them I the stuck them on. I'll look for the arrows!!!! Quote Link to comment Share on other sites More sharing options...
