monty Posted June 21, 2011 Share Posted June 21, 2011 a new design for a ring, silver soldered then acid bathed to remove oxidation i left the brass ring open for easy size ajustment Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 21, 2011 Share Posted June 21, 2011 Curving them generally makes them a bit more friendly to wear, is it new to you? That design goes way back. Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted June 21, 2011 Share Posted June 21, 2011 Nice start! I have found that for adjustable rings if you make it so that the ends bypass each other it is more comfortable for the wearer of the ring. That way there is no point to come together to pinch the finger. Quote Link to comment Share on other sites More sharing options...
monty Posted June 22, 2011 Author Share Posted June 22, 2011 ok points taken! Quote Link to comment Share on other sites More sharing options...
Alec.S Posted June 22, 2011 Share Posted June 22, 2011 Love that design idea!! alec Quote Link to comment Share on other sites More sharing options...
Dodge Posted June 24, 2011 Share Posted June 24, 2011 Do you apply anything to the brass ring to prevent the wearer's skin from turning green? B) Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted June 24, 2011 Share Posted June 24, 2011 Do you apply anything to the brass ring to prevent the wearer's skin from turning green? I like the ring but as Dodge asked, I was also worried about the finger turning green. Quote Link to comment Share on other sites More sharing options...
monty Posted June 26, 2011 Author Share Posted June 26, 2011 i thought it was copper that turned skin green, does brass do the same? Quote Link to comment Share on other sites More sharing options...
Dodge Posted June 30, 2011 Share Posted June 30, 2011 i thought it was copper that turned skin green, does brass do the same? Brass "rusts" or corrodes leaving green residue as well, but on skin it could actually leave a black ring. It usually washes off with a scrubbing with good ol' S&W, however :) Quote Link to comment Share on other sites More sharing options...
wshelley Posted June 30, 2011 Share Posted June 30, 2011 In the FWIW category, brass is an alloy of copper and zinc, hence the green ruboff. There are lots of different alloys and they will react differently based on the individual wearer's chemistry. Ward Quote Link to comment Share on other sites More sharing options...
