June 14, 201115 yr Hi guys I have smithing for a while but have to pack up every tool, piece of steel and other object I use. This includes a 150kg (240lb)anvil! I would like to build my own smithy but want to get a basic design before I get official plans from an architect. I have come come uo with a basic plan: the smithy will be a half circle with straight walls extending from the ends of the hemicircle(new word?), With the main forge's centre on the same line as the half circles edges. I have attached a rough(very rough) plan of the smithy. Any help is appreciated Thanks Jordan.
June 14, 201115 yr Well since you will be doing a lot of work with 20' lengths of heavy steel make sure the main work stations are far enough apart to be able to swing a stick! Oops---Since you really want to concentrate on knifemaking make sure your work triangle is really really close! Or we can't really make many suggestions until *YOU* tell us what *YOU* want to do in your shop! What suits one smith very well might be criminal negligence for another smith. (Like when I was looking up how anvils were pointed in old smithing books---point left vs point right---and the first one I found had the horn pointed directly towards the forge---guess they did a lot of rings in that shop.) The basics are to manage the "work triangle": Forge Postvise Anvil or "work square" Forge Postvise Anvil and Powerhammer so it fits your needs---small work: make it tight with one step at most between them. Large work: make it so it's easy to move large pieces of hot metal around without them running into things.
June 14, 201115 yr My smithy is round. You can see what it looks like here : But, like Mr Powers said, it depends on what you do. I make small harware. It is the best set up for what I am doing at this time. Look around this site. It's full of great ideas. Yves
