Steve Sells Posted June 8, 2011 Posted June 8, 2011 here are the tripods set up, with either using the doubled ends through the loop, (5,6,7) or with the single sides (8,9) Quote
Marksnagel Posted June 8, 2011 Posted June 8, 2011 Steve, That is so cool. I thrive on simplicity. Thanks for posting the pics. One of these days I'll have an origonal idea but until then I rely on others. How long are the pods I reckon they would be called pods. Threepods, treypods? Thanks again, Mark <º))>< Quote
ThomasPowers Posted June 8, 2011 Posted June 8, 2011 Pod means "foot" are you asking about the upper ends? triTets? I make mine fairly deep to help avoid accidents when someone bumps them; but the exact length is done by eye for the first one and then the other is matched to it. Every thickness of stock has a different "pleasing to the eye" for me and I'd note that the round end generally takes up less stock than the U ends so I don't cut into 3 even pieces when I start but generally give an inch or so for each U off the O piece. However when you are starting out making them even and then trimming the long one is an easier method. I generally try to size them so that they will evenly come out of one or more 20' sticks: eg: 4 5' lengths = 1 tripod + 1 leg for the next one And don't forget: when you are cutting multiple pieces from a long bar make the first cut at a sharp angle \ not | so that two legs are already almost pointed! Saves forge time. Quote
