monty Posted May 17, 2011 Share Posted May 17, 2011 i have recently purchased a new anvil but have no idea what it is made from, it definately has a plate welded on for the face though Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 17, 2011 Share Posted May 17, 2011 Pictures would help... #1 Check the ring, if it doesn't ring most likely it is cast iron, #2 look for a mold seam running from the middle of the anvil up, #3 who made it, some manufacure only made cast iron, #4 does it have handling holes--little square holes under the horn and tail used to handle the anvil while forging, #5 did I mention pictures? There are other ways, these are just a few easy ones. Where ya from? The UK is fairly big. There could be someone just across the street from you that could help but we don't know that if we don't know where you are? Oh yeah, pictures would help. :rolleyes: Link to comment Share on other sites More sharing options...
MattBower Posted May 17, 2011 Share Posted May 17, 2011 i have recently purchased a new anvil but have no idea what it is made from, it definately has a plate welded on for the face though Are you sure it's really a welded on steel plate? Some of the cast iron ASOs are cast so that the face protrudes slightly from the body at the joint between the two, to make it look as if they're separate pieces. Very sneaky. Almost fraudulent, really. If there's really a welded on plate, it'll be made of steel (never heard of anyone welding anything else onto the face of an anvil), and the anvil is very likely of decent to excellent quality -- unless it's been damaged. Link to comment Share on other sites More sharing options...
monty Posted May 17, 2011 Author Share Posted May 17, 2011 south lincolnshire there are two videos on youtube also my old anvil has handling holes, what does this mean? what do handling holes mean in terms of quality, my other anvil has them (you can see it on youtube my channel is roglet123) also the new one has blobs of mig welding on it if that means anything. the face overhang is also noticeable in the hardie Link to comment Share on other sites More sharing options...
MattBower Posted May 17, 2011 Share Posted May 17, 2011 I can't see the vids from behind this firewall. I'll look later. The MIG welding means someone has been MIG welding on the face, which isn't a great sign. It means the face may have been tempered back some, or worse. I consider handling holes a positive sign. They mean someone was welding and/or heat treating the anvil, which means it probably isn't cast iron. It could have suffered all sorts of indignities in the intervening years, but it probably wasn't total junk when it came out of the factory. Link to comment Share on other sites More sharing options...
monty Posted May 17, 2011 Author Share Posted May 17, 2011 the handling holes arent on the one that may or may not be cast iro, they are on the other, glad that thats a good thing tho! Link to comment Share on other sites More sharing options...
TechnicusJoe Posted May 17, 2011 Share Posted May 17, 2011 The 200 pounder looks like a Fisher to me, it has those two hole at the back and front of its feet to put a bolt. It doesn't really seem to ring to me, so I'd say cast-iron. Fishers are cast-iron anyway. Link to comment Share on other sites More sharing options...
monty Posted May 17, 2011 Author Share Posted May 17, 2011 so a fake face plate seam? and the face overhang is also noticeable in the hardie Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 17, 2011 Share Posted May 17, 2011 Fishers have cast iron bodies with a nice thick tool steel face and are a superior anvil compared to plain cast iron anvils! Link to comment Share on other sites More sharing options...
Bentiron1946 Posted May 17, 2011 Share Posted May 17, 2011 Nice looking Fisher you got there, it'll be nice and quiet to do your forging on. I have a 300# Fisher and like it a whole lot. :P Link to comment Share on other sites More sharing options...
Drewed Posted May 17, 2011 Share Posted May 17, 2011 Nice anvil! Looks like fine bounce. That paint is going to smell like poo when you start forging on it! Link to comment Share on other sites More sharing options...
monty Posted May 18, 2011 Author Share Posted May 18, 2011 so is it any good? i sanded the paint off the face would you say it has a face welded on? Link to comment Share on other sites More sharing options...
Drewed Posted May 18, 2011 Share Posted May 18, 2011 Not to answer a question with another, but as I've found out ( mostly from this site! ) is...Who cares what is made out of as long as you enjoy working with it. To me it looks like a nice flat face, great rebound, and not a nasty ring, so I say go get your rod hot hot and beat it! :P Link to comment Share on other sites More sharing options...
mattinker Posted May 22, 2011 Share Posted May 22, 2011 are there any spark tests or something? When looking into my Anvil, see thread precedent (Old French Anvil), I did a spark test, on the side of the horn, then, I realised that if it had a plate welded on the top, it would spark differently. What I had thought was a work created bulge spreading out around the whole of the upper face was in fact a steel plate. the top sparked differently from the side! regards, Matthew Link to comment Share on other sites More sharing options...
Please sign in to comment
