mat Posted May 12, 2011 Share Posted May 12, 2011 hi all i have a i nash and son anvil there is a very thin line /crack? at the heel,there is no sound change when tapped around with a hammer,could it be a weld if the top plate was welded up in 2 or more sections? so i am weary of heavy work at the hardy,so i thought i would make a stake holder/tool holder/ bolster.all from free scrap,all mild steel except the cog it rings like a bell.i still have to file the hardy(1 in sq)and weld.top plate is 4in sq by 3/4in,under that its 2 bits of 2in by 5in and 1 small bit 1in by 2in sq.the heavy bar is 5in across by 6in tall,the cog is 17in across by 3 1/2in deep.all up 65kg 143lbs.it will be able to take a tool shank 2 1/2in long.i will leave one side under top plate open to help if anything gets jamed.it will be set on a log and some pins driven detween the cog teeth to stop movement thoughts thanks mat Quote Link to comment Share on other sites More sharing options...
Dogsoldat Posted May 12, 2011 Share Posted May 12, 2011 Looks handy. Any idea what the gear use to run. Don't know that I have seen anything quite that large. Quote Link to comment Share on other sites More sharing options...
mat Posted May 12, 2011 Author Share Posted May 12, 2011 Looks handy. Any idea what the gear use to run. no it was found on wast ground near a big rusted out fly wheel or train wheel?? i seem to have a knack of finding heavy lumps of metal,i should move to the gold fields lol. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 13, 2011 Share Posted May 13, 2011 Looks like a weld on the face plate---where 2 of the face pieces were welded side by side to the anvil. If the ring is good there isn't a problem *currently*. Always a good idea to to shift heavy work off the heel! I'd drift a hardy hole in the top piece, far easier than filing to me! Quote Link to comment Share on other sites More sharing options...
