December 13, 200619 yr Hi, Has anyone got anyone got a simple (cheap) bearing setup for a small weathervane? Total height is about 2 ft. Brian.
December 13, 200619 yr I point the top of the support shaft, then round it slightly. I seal the top end of the outside support pipe. Drop a single ball bearing in for the top bearing. I put a gob of light grease on the top end of the support shaft when I insert it when the vane is completed.
December 13, 200619 yr My old master used to just grind a cup on top of the mounting shaft, then slide the pipe of the weathervane top over that with a ball bearing in between.
December 14, 200619 yr I read somewhere that you could use a bicycle pedal. Use the side that has right-hand thread, and you can use that threaded end to mount it to something, and the top end already has a dust cap on it. Cut off the rest of the pedal. This would be good for heavier loads and where there is a risk of weathervane being lifted off. From a pracital point of view, I like the single ball bearing idea though.
December 14, 200619 yr Actually two bearings works better. The lower one on the shaft should be a little smaller than the top one. Gobbler
December 14, 200619 yr iv heard that the ball bearing is the best way, with a point or small radius on the shaft
December 14, 200619 yr Author Thanks to all for your help.Got the idea.Now....where's me collection of old bearings got to?
December 15, 200619 yr you might also consider inline skate bearings, I use them often to make motorcycle wheel truing/balancing stands. small size cheap and available.
