January 17, 201115 yr Literally minutes after I made a post about help finding a large post vise I came across this when i went to pick up some steel for Lisa..Its a brute, the jaws aint that wide (3 1/2") but its super heavy duty. Its setting on top of a 200 pound fisher..A mounting palte will be easy to make.. Not a leg vise but I couldent pass it up for $35..
January 17, 201115 yr Its a "Cole" vise. I have one in my junkpile I found in the trash. Mine is cast iron/steel and has been welded & brazed back together several times at the pivot point at the bottom by previous owners. I wouldn't beat on it to much for fear of it cracking near the pivot.
January 17, 201115 yr Author I know its no substitute for a good leg vise. I have a good 4" leg vise and am looking for a bigger one..I just couldent pass this vise up for $35 I figure it will make a good vise for the work bench...
January 17, 201115 yr It is a decent vise and can even be made into a pseudo leg vise by putting an 1-1/16"(if I remember correctly) piece of CRRD into the bottom hole. Cole also manufactured the infamous Cole drill which is highly sought after. I used to have the vise but hard times forced the sale in years past. I still have the drill though. The neat thing about the vise is you can detach it from the ASO mount and use it as a very large pipe wrench by putting the CRRD in the end. I sometimes wish I hadn't sold it but truth be told I seldom used it. Good buy for $35 though !!!
January 17, 201115 yr Its a "Cole" vise. I have one in my junkpile I found in the trash. Mine is cast iron/steel and has been welded & brazed back together several times at the pivot point at the bottom by previous owners. I wouldn't beat on it to much for fear of it cracking near the pivot. Mine had been broken once before as well. Had to weld it back with nickel rod. Needless to say I have more in the weld job than the vice cost me. Don't over stress it and it should work fine for small jobs
January 18, 201115 yr Got one too; but it's not mounted as I have a plethora of post vises and a couple of good machinist vises. Picked it up in OK about 29 years ago.
January 19, 201115 yr If you have a Cole drill they can be a handy pair, they swivel 360 deg which can be handy too.... But to me its really about the drill/vise as a pair if you want to do something.. If you just need a good vise, id find something else ( I gave mine away)
January 19, 201115 yr I don't have one but I wish I did . A friend of mine has one and he uses it allot. Weld positioning small stuff, grinding, filing when a static vice is an impediment. I'd never hammer on it with anything larger than a medium hand hammer, most of em' get cracked by some yahoo attacking frozen bearing or some sutch with a sledge. Post vice apple, cole vice orange...............mb
January 19, 201115 yr Author I thought it might make a good filing vise where the jaw swivels and its holds round bar so well..
