Farmall Posted December 3, 2010 Share Posted December 3, 2010 but don't know much about it...was used in a fellow's grandfather's fabrication shop until 1941 when it got put in the barn. It looks like the top was rewelded to the bottom....but it rings like a bell on all sides from top to bottom..am going to clean it off with a wire wheel and see if I can find any markings....any ideas on what it might weigh? It is 29 inches long by 3-1/2 inches wide. Was all I could do to lift it straight up onto the tailgate of the pickup. I hope I can figure maker out, and I'll weigh it this weekend. 'Preciate any and all help. Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted December 3, 2010 Share Posted December 3, 2010 The hourglass depression under the base and the overall shape makes me think it's a Hay Budden. There might be a serial number on the front of the foot. If you can provide the number, someone will be able to tell you the year of manufacture. If it is indeed a Hay Budden, they usually had the weight stamped on the sides below the name stamp. Quote Link to comment Share on other sites More sharing options...
Farmall Posted December 3, 2010 Author Share Posted December 3, 2010 Thanks....got some cleaning to do and hope I find some markings......got this for $100 to get it out of the way.... Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted December 3, 2010 Share Posted December 3, 2010 You did well! Quote Link to comment Share on other sites More sharing options...
maddog Posted December 3, 2010 Share Posted December 3, 2010 Great deal! It does look like an HB. Check above the left front foot under the horn. If there is a single digit about 5/8" high stamped there, its almost surely an HB. Looks like the plate is sound, the edges are good and just a bit of swayback around the sweet spot in the center. Looks like there are a couple of cutting torch nicks in the edges which is not unsual. It looks great! Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted December 3, 2010 Share Posted December 3, 2010 Farmall, You got a great deal on your "New" anvil. I was just wondering where I am when great deals like this are to be found. Then it dawned on me, right here looking at someone else's great deals. I need to get out more often. Enjoy it! Mark<>< Quote Link to comment Share on other sites More sharing options...
Dick L. Posted December 3, 2010 Share Posted December 3, 2010 I'm wondering how / why the top got separated from the bottom ! Dick Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 3, 2010 Share Posted December 3, 2010 They were made in at least the two pieces and in "recent times" they were arc welded together. Earlier times they were forge welded together---ever have a forge weld fail? On my wall of shame I have the base from a 100+ pound anvil that the entire top is missing---weight stamped though so I know it was once complete. Postman said it's most likely a PW. Quote Link to comment Share on other sites More sharing options...
Farmall Posted December 3, 2010 Author Share Posted December 3, 2010 I'll post some more pics once I get'er all cleaned up so we can all see the weld job. Rings solid, even through that weld. measured it wrong too....face is about 4-1/2 inches by 18, so that seems like it would be around 200# based on the HB literature..... Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted December 3, 2010 Share Posted December 3, 2010 I seem to remember a story in Anvils in America where occasionally they could hear the tops of the Trenotn anvils popping off once they were all finished due to changes in materials from wrought iron to steel making the forge welds harder to 'stick'. Trenton started arc welding the tops and bottoms together shortly thereafter. Quote Link to comment Share on other sites More sharing options...
