Laoich23 Posted December 2, 2010 Share Posted December 2, 2010 Got a hold of two fork lift forks, apparently they were made from cutting one larger single fork into two, for a smaller lift. So now, I plan on using the faces of the upper back part as the anvil face, the rest for the body. My question is what is anyone's thought on welding these two parts back together so that there would be a 6"x14" face rather than 3"x14" Would the weld, if I use wire for high carbon, causes trouble later on? Could it survive being heat treated? Also, I can cast non-ferrous metals, I wast thinking of filing the middle with copper or bronze for extra mass, and because I can. What do ya'll think, would it help deaden the ring? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 2, 2010 Share Posted December 2, 2010 I think that you would do much better to arrange for a smaller face with more metal vertically below it. However not knowing what you plan to do with it I can't say much about how it should look---I need to buy a vehicle can you tell me if I need a dump truck or a racecar? May I commend this to your attention as a method of making a forklift tine anvil: http://www.marco-borromei.com/fork.html and yes I am the Thomas mentioned in it. Quote Link to comment Share on other sites More sharing options...
Laoich23 Posted December 5, 2010 Author Share Posted December 5, 2010 Yeah, changed my mind, just gonna keep it simple, and stack them and keep the face 3X14 Quote Link to comment Share on other sites More sharing options...
pip Posted December 6, 2010 Share Posted December 6, 2010 hey if you got the forklift Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 6, 2010 Share Posted December 6, 2010 I found one that was run off a bluff onto the spoil pile by a river when a factory closed and was cleaned up long ago---6" trees growing through it. Was a bit of a pain lugging a 180# tine out of the woods by myself... Quote Link to comment Share on other sites More sharing options...
