felix24 Posted October 14, 2010 Share Posted October 14, 2010 Hello there, I'm new to the forum and still quite new to the world of bladesmithing (this is my 6th knife). Just thought I'd post up this knife as a way of saying hi. It's one I made for my Dad as a birthday present. The blade is made from O1 tool steel, the bolster is mild steel. Not too sure what type of wood the handle is. Looks nice though It has a hidden tang with a bras pin to hold it in place. In terms of heat treating, I normalized it three times and then annealed it before filing and sanding. Then I quenched it in cooking oil and differential tempered three times with a small blow torch. Going for light blue along the spine bleeding into straw along the edge and purple for the tip. The tang was tempered all the way to a grey colour. Let me know what you guys think ;) Quote Link to comment Share on other sites More sharing options...
Chad J Posted October 14, 2010 Share Posted October 14, 2010 That looks like a great knife! i like the file work, Beautiful! Chad Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted October 15, 2010 Share Posted October 15, 2010 Have you tested any of your knives to destruction to test the heat treating? The reason I ask is that I work with some parts made of O-1. I recently had to anneal a bar loader collet in order to retap it to a larger size. I heated it red hot, and put it in some kitty litter to cool it slowly. The next day it was still to hard to drill, and a file slid on it. I ended up heating it to a dull red on some fire bricks, and heated the bricks also. When all was smoking hot I closed them over the collet, and that did the trick. I have found that O-1 needs some soak time to draw a temper. It isn't like plain 10 series steels that easily draw with a torch, and watching colors. Quote Link to comment Share on other sites More sharing options...
golgotha forge & anvil Posted October 15, 2010 Share Posted October 15, 2010 That's a great looking little knife...filework is really good ! Gene Quote Link to comment Share on other sites More sharing options...
mrkiddi Posted October 15, 2010 Share Posted October 15, 2010 Really nice:) that thing is pretty, and the handle is nice. you are really talented! keep us updated with your work! Quote Link to comment Share on other sites More sharing options...
felix24 Posted October 15, 2010 Author Share Posted October 15, 2010 thanks a lot for the compliments guys BIGGUNDOCTOR, no I have never tested completely to destruction. So far I have tested my knives by cutting paper, cardboard and wood and seeing if it will still shave my arm. Also I jam the tip into a piece of wood and jiggle it around to see if it will curl or chip. If not them I'm pretty happy. All the knives I have made so far are pretty small, so I haven't done any chopping tests with them. I'm working on a knife at the moment using a piece of coil spring. I'm not sure exactly what type of steel it is, but I'm planning on giving it a good hard test (cutting, chopping, bending) after I heat treat it to see what it can do, and to see (as you say) if I heat treated it properly. Hopefully I'll get some good results :) Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted October 16, 2010 Share Posted October 16, 2010 Nothing wrong with a small knife. I use my old Schrade pocketknife for a LOT of work; opening boxes, cutting letters open, skinning various road kill for tanning practice, cutting lunch items up, wood carving, and a lot more. I use my knife just about every day. I can't say the same for the large sheath knives I have which stay in the dresser drawer. BTW the file work is very nice. Personally I think it looks great, but I would probably use only various radii, no sharp corners in order to avoid stress risers. Overall I really like the design, and I am sure that your dad will treasure it. Quote Link to comment Share on other sites More sharing options...
felix24 Posted October 16, 2010 Author Share Posted October 16, 2010 That's a good point about the stress risers. I'd say the most work this knife will get is disembowelling letters though. I'll keep it in mind though for future knives :) Quote Link to comment Share on other sites More sharing options...
golgotha forge & anvil Posted October 17, 2010 Share Posted October 17, 2010 Please keep us posted on all future endeavors !! Gene Quote Link to comment Share on other sites More sharing options...
