Worth 50$?
http://cgi.ebay.com/Vintage-Blacksmith-Forge-8-Blower-turns-freely-/110558380579?pt=LH_DefaultDomain_0
No screws to hold body together, no handle/crank hard and couples 'paddles' look like they
were patched, jb weld or epoxy maybe?
...but with shipping, 50$
For that much you could make your own bellows. I'd pass
Good enough sampling of replies, thanks folx. :-)
why pass? all you need is a belt to drive it and some machine bolts to bolt it back together, after all it's a forge blower that mounts directly below the forge - (notice the mounting tabs). buy it a put it back to use as it was intended instead of the scrap pile filler. - JK
Tell him it's too much money and work, maybe counter offer $20.
Frosty the Lucky.
...again wanted to say thanks for the comments, found a local CL post last night
and picked this up earlier today instead. Seems to turn/blow fine, get's right
about 2 'turns' on it's own when you let go.
Not sure the best way to clean the outside...
post-14529-057014900 1282102542_thumb.jp
post-14529-051597200 1282102554_thumb.jp
Clean it!!! Why? It'll just get dirty again :P
Good score
