Cable Sources
eric sprado
Hey Eric,
Here's a place that sells it by the foot. I just ordered 6' of the 1-1/4" dia and they didn't ask why. They still have grease and a plastic strip down the center that said made in the USA, but not like the well used ground in grease and grime of the 2nd hand stuff.
www.webriggingsupply.com
elliscustomknifeworks.hightemptools.com
Hope this helps.
Chad J
P.S. I'll keep adding links as i remember them.
Hey Eric if you want new cable look in the yellow pages under wire rope, I found thats how its listed here. Also I never used anything but old cable from the beginning and it will weld up just the same. Here is an old group of pictures I put together one time, I have posted these before, but I still do basically the same process when I weld cable, accept I made a tool that is easier to use than the step of the anvil. Brian Brazeal made one too, and he welded some cable this way also.
Good luck and show us some pics when you get some welded up.
http://picasaweb.google.com/LDWynn/BirthOfACableKnife#
