peacock Posted April 16, 2012 Share Posted April 16, 2012 Little Giant dovetails are 10 degrees. The key angle is 1/8 in 12 = an angle of 35 min 47 sec or slightly over 1/2 degree Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted April 16, 2012 Share Posted April 16, 2012 As far as tooling goes John, have you thought about investing in having a tool body made that would allow you to use something like off the shelf triangular carbide inserts to machine the angles you require? The carbide inserts will wear out but the body never does unless it`s abused, not that you`d ever do something like that. Quote Link to comment Share on other sites More sharing options...
John Larson Posted April 18, 2012 Share Posted April 18, 2012 Thanks, Phil, for the LG numbers. I stand corrected and if I still have a die in the shop I will double check it. Thanks Mainely Bob. Yes, essentially that is what I was asking about just above. My machinst buddy who makes my 7 degree HSS cutters is good, but makes me wait too long sometimes. So the carbide inserts would get me past that bottleneck. I am mainly concerned about staying aligned with Brian Russell on the angles because he is my supplier of S7 dies. I can remember back in the Keenjunk forum days almost begging for info on the angles and the site was useless. I copied Tom Clark and Uri Hofi because I used Tom as a die supplier for a while. Then I made my own for a long time staying with the Clark/Hofi/Turkish/German angles. I then switched to Sahinler dies on my bigger hammers and special Iron Kiss dies from Brian. Sahinler is also a German knock off made in Turkey, albeit a very old firm. At this point I have strong motive to not change to another set of angles, obviously, and I must say also that I have been satisfied with the 1 degree and 7 degree angles. FWIW, in Bob Bergman's video on rebuilding Nazels, he shows a special hammer he built for knocking loose a Nazel sow block wedge. The 1/8 in 12 (plus years of seating in) is a bit of a problem that he solved with the battering ram type of special hammer. Quote Link to comment Share on other sites More sharing options...
kerrystagmer Posted January 27, 2013 Author Share Posted January 27, 2013 I recieved a phone call last night, the machine shop has finally completed the front end work on this hammer. New cushion plug and bushing, truing of the tup, new guide plates(iron this time!) to match the new bore size with bronze pins, weld up and recutting of the dovetail, completely repaired guide ring with steel mounting flange interferance fit and bolted to the existing ring. I expect to be picking up the parts on wednesday. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted January 27, 2013 Share Posted January 27, 2013 :-) Quote Link to comment Share on other sites More sharing options...
monstermetal Posted January 27, 2013 Share Posted January 27, 2013 Good deal.... I finaly got my 4B back together as well.... it runs but has some control issues. I hope ol blue runs like a top! Quote Link to comment Share on other sites More sharing options...
John Larson Posted January 27, 2013 Share Posted January 27, 2013 Surew hope to see that big guy running and working at Fire & Ice 2013. Quote Link to comment Share on other sites More sharing options...
kerrystagmer Posted January 27, 2013 Author Share Posted January 27, 2013 Right there with you John. Same guys have the 2B parts but at this point if they would just press off the flywheel I have made other arrangements. We would be using the 2b constantly. Quote Link to comment Share on other sites More sharing options...
