Patrick2586 Posted May 18, 2010 Share Posted May 18, 2010 Hi there, Northern tools & equipment is having a really good deal on a 60lb anvil. The reviews are very mixed though.My link It would be my first anvil and i am some what on a budget. I would not be doing heavy work on it just yet. Is it better then a modified rail road rail? Thanks for your answers Patrick Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted May 18, 2010 Share Posted May 18, 2010 My advice would be to sit on your wallet and keep looking. Cast iron instead of steel, no hardy or pritchel hole. Pretty limited to what you would be able to do with it. Your rail iron will do for quite a while till you find a beauty. Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted May 18, 2010 Share Posted May 18, 2010 Another fine example of an ASO! (anvil shaped object) Rob's advice is worth considering Quote Link to comment Share on other sites More sharing options...
Tate Roth Posted May 18, 2010 Share Posted May 18, 2010 I have one of these anvils acting as a lawn gnome helper. When I told my parents I was starting to blacksmith a few years ago, they ordered one for me and had it delivered to my house. It's funny since they are in ND and they had northern tool deliver it to my house, which is two blocks away from one of their shipping centers. Luckily, I already had picked up my Nimba. The northern tool anvil is cast iron, had a huge casting seam down the face, and little or no rebound. I ground the face flat and set it outside, and sometimes I let my boys bang around on it with copper to be like daddy. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted May 18, 2010 Share Posted May 18, 2010 that is scrap metal... keep lookin geta used good anvil..even if it costs more it will be worth it.. and a good used anvil you can resell if you decide you dont need it anymore .that cast iron ------ will never be worth anything .. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 18, 2010 Share Posted May 18, 2010 Patrick; you would be better off just getting a hunk of steel from a scrap yard and using it as an anvil. I have used a cast iron anvil---a 220 pounder and it dented under cherry red spring steel when I was trying to pound out a blade! A chunk of fork lift tine may very well suit you better than the RR rail and may be found cheap if it's damaged and you make sure they know that it will *NOT* be re-used for lifting---a liability concern! Quote Link to comment Share on other sites More sharing options...
don't tread on me Posted May 18, 2010 Share Posted May 18, 2010 I had a 55 pounder from Habor Fraight and it dented with a bright orange RR spike. This pic is before I evar used it. Quote Link to comment Share on other sites More sharing options...
Thermalfun Posted May 19, 2010 Share Posted May 19, 2010 I agree with rob if you plan to use the anvil for hot work. But the ASO's work well for cold work. Bending, folding, and riveting is what it does perfectly. I wish I still had mine because I am hesitant to drill rivet half spheres into my hot work anvil. It all depends on what you need it for. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted May 19, 2010 Share Posted May 19, 2010 I agree with rob if you plan to use the anvil for hot work. But the ASO's work well for cold work. Bending, folding, and riveting is what it does perfectly. I wish I still had mine because I am hesitant to drill rivet half spheres into my hot work anvil. It all depends on what you need it for. Need to just make up a hardy block and drill the rivit halves in the block. Best of both worlds. Ken. Quote Link to comment Share on other sites More sharing options...
MattBower Posted May 19, 2010 Share Posted May 19, 2010 Drill holes in....wha? I'm with Ken! Quote Link to comment Share on other sites More sharing options...
