Ayers Garage Posted April 16, 2010 Share Posted April 16, 2010 I'm sure you fellows get real tired of the same old subject, but I figured I'd beat the dead horse again. Can anyone shed some light on to what kind of anvil this is ? Forgive the boot print on top of it. If you lay something down at the fire station, some wise guy is going to have to perch on top of it like a chicken. On the side... On the front near the bottom base... I'd appreciate any insight on the matter. Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted April 16, 2010 Share Posted April 16, 2010 Based solely on the location and style of the serial number I would guess Hay Budden, probably manufactured for someone else (like a hardware store chain or...). Do you have any pictures of the underside of the base and heel? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 16, 2010 Share Posted April 16, 2010 I'd just add that it's weight stamped in pounds and not CWT. A pick of the underside of the bottom would help a lot. It looks to be a wrought iron anvil with a welded on faceplate. Plate looks a tad thin please don't make it any thinner by aggressively "cleaning it up" a simple wire brushing should do fine; or even just work hot steel on it and let that clean it up. Quote Link to comment Share on other sites More sharing options...
Ayers Garage Posted April 16, 2010 Author Share Posted April 16, 2010 I appreciate the insight so far fellas. Here is a picture of the bottom. It's seen some miles in it's life... Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted April 16, 2010 Share Posted April 16, 2010 Yep, I would say Hay Budden based on the hourglass depression. Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted April 16, 2010 Share Posted April 16, 2010 I'l add a vote for Hay Budden given the shape of the underside. Also looks like it sat in the dirt for 50 years or so, or the depression was forged with a ball pein. Thomas- at first I also thought it looked like it had a face plate, but one of the photos looks like it has a forgeweld at the waist as well which points me back to an all steel top.. Assuming my reading of the serial # is 17xxxx Anvils In America would date it to around 1910, the same source indicates that HB went to their famous solid steel top half around 1909, but perhaps I'm misreading the serial number. Good anvil none the less. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 16, 2010 Share Posted April 16, 2010 Earlier HB's often didn't have very large rims around the base depression making them easy to wear flat. (I have one that's nearly worn flat---bought it at a plumbing/HVAC co auction---they moved to their "new" building in the 1930's....) That one looks faily broad to me so it might be a later one---however the stamping looks quite crude which would push for an earlier date. My anvil also has a much thicker face on it than that one shows. Fun. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted April 17, 2010 Share Posted April 17, 2010 Add one more vote for H-B made for another store. does look like a thin plate. Look on the other side just bolow the hardy hole. All the tool steel tops I have seen have 3 # stamped in there.(mine does) Ken Quote Link to comment Share on other sites More sharing options...
