Bearded hawk
I wanted a small hawk for splitting kindling so this is what i decided to make.
Forged from a wrought iron wagon wheel with a piece of a file for a bit.
The head is 4" across with a 3" edge. This wrought has more silica or slag than i have ever seen in wrought iron.
Thanks for looking and your comments.
Bob
Wagon tyre is often Merchant Bar, (Bloom => Muck Bar => Merchant Bar => Singly Refined => Doubly Refined => Triply Refined...), and as such is often preferred by blademakers for fittings as it has more "character". Back in the day they would generally try to use better stuff to avoid character...changes in style and how we perceive stuff.
Thanks for the comments guys.
Winterbear i posted this on another forum.
I cut pieces of wrought iron tire one about 8" long and two 3" and cut a 3" piece of an old file.
Heated and wrapped the 8" piece around the horn of the anvil and allined the open ends together.
Then forge welded the file inside the two 3" pieces of wrought placed it between the open ends of the first piece fluxed at red brought it up to welding temp and forged the whole thing together forged it down a bit then filed and ground to clean it up.
I did not clean the rust off of anything at welding temp it gone.
Most wrought iron has lots of layers in it ,this was just straight from the tire once you forge and grind it it usualy looks like this with a quick etch in ferric cloride.
Bob
  • 1 month later...
Bob
looks great Bob, love the oily look n the iron!
  • 5 months later...
