January 27, 201016 yr I have found some wrought iron but it is archetectural wrought iron and im afraid its not refined enough for forging into smaller pieces. Whats your take on archetectural wrought iron?
January 27, 201016 yr Hi there, Just a couple of questions/thoughts. When you say architectural iron can you describe what is it exactly. The best thing I have found with unknown quatity iron is forge some test pieces. I don't know how much wrought iron you have forged, but the most important thing for me is forging at the proper temperatures. I start at a white heat then more importantly stop at a medium orange. This has helped me to stop the splitting apart problem. Good luck, Mark
January 27, 201016 yr I have found some wrought iron but it is archetectural wrought iron and im afraid its not refined enough for forging into smaller pieces. Whats your take on archetectural wrought iron? If it is architectural wrought iron it has already been forged, so the quality should be reasonable, I would think you have some form of cast architectural iron, and that is a whole different material!
January 27, 201016 yr I have found some wrought iron but it is archetectural wrought iron and im afraid its not refined enough for forging into smaller pieces. Whats your take on archetectural wrought iron? If it is a low grade wrought iron then refine it some more then by more forging, fold reweld and forge some more.
January 27, 201016 yr Yellin specified triply refined wrought iron for his architectural work. Simple pickets may be lower grade *BUT* it is most likely to be a good grade of WI and not Merchant bar like many wagon tyres are! Try it and see!
January 27, 201016 yr It is Wrought Iron. It was used in railings and such,, So was cast iron, try a spark test or "snap test" and that should help determine what it is
January 27, 201016 yr Author Its wrought, theres no doubt about that. Thanks guys, I think Ill give it a try.. Its got to be forged a bit anyway as its in square bars..
January 27, 201016 yr Its wrought, theres no doubt about that. Thanks guys, I think Ill give it a try.. Its got to be forged a bit anyway as its in square bars.. just remember to forge it at the right heat, and it should forge down OK
