September 7, 200916 yr I'm not sure if this is the right place to ask , but does any body know where to have a custom hot or cold stamp made? I normaly use a leter punch set but some times they come out crooked.
September 7, 200916 yr If you do a search on the forum you can find several companies that make touch marks. Touchmark has over 50 hits, touch mark has over 40 hits.
September 7, 200916 yr By using the search feature at the top of this page I found discussions of touchmarks. Here are a few of the links to those discussions.http://www.iforgeiron.com/forum/f7/making-touchmark-3594/http://www.iforgeiron.com/forum/f92/show-me-your-touchmark-13852/http://www.iforgeiron.com/forum/f38/marking-signing-piece-13961/http://www.iforgeiron.com/forum/f7/touchmark-register-10521/http://www.iforgeiron.com/forum/f11/using-touchmark-11157/http://www.iforgeiron.com/forum/f8/forge-name-touchmark-design-would-welcome-input-13507/http://www.iforgeiron.com/forum/f7/touchmark-4016/http://www.iforgeiron.com/forum/f11/touchmark-9946/http://www.iforgeiron.com/forum/f14/using-makers-marks-9403/http://www.iforgeiron.com/forum/f11/custom-chisels-engraving-text-steel-9182/
September 7, 200916 yr I've tried making my own touch marks with little to no success. I found a guy that I think is less expensive than most the others I contacted and have gotten stamps from him. You can even send a sketch or picture of what you want and he will make a custom stamp for you. He also has a bunch of pictures of stamps you can choose from. He will email what the stamp will ultimately look like and you can make changes before he makes it. It's called Buckeye Engraving. The address is 4485 Crystal Pkwy: suite 200 ; Kent, OH 44240, Phone is 330 677 5685 and fax is 330 677 3936. I found it simpler to email him at [email protected] If you decide to use him, let him know that Cindy in Missouri recommended him.
September 7, 200916 yr Apparently Buckeye Engraving has a website as well: Buckeye Engraving Custom Steel Hand Stamps
September 8, 200916 yr Author Thanks again. I did a search on this site for makers mark, and had only one hit so I thought I would ask and once again it proved most informative.
