junker Posted July 30, 2009 Share Posted July 30, 2009 So I use the standard 55gal drum with tube in bottom to make charcoal... problem is that from a full barrel of wood I get less than an eighth of a barrel of charcoal. I use pine, should I be using a differnet fuel for more charcoal? And is there anyone out there with a more efficient method... cause at this rate I'm gonna cut my whole woods to the ground in 5 years. Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted July 30, 2009 Share Posted July 30, 2009 Here you go Junker, this is called a retort kiln or charcoal kiln. When I get to the point I will be making my own, this is how I'm going to do it. He seems to have allot of very good sucess with it. Good luck!Making Charcoal Quote Link to comment Share on other sites More sharing options...
junker Posted July 30, 2009 Author Share Posted July 30, 2009 thanks 4 the link... sadly i am stuck with the direct method do to the avaliability of materials... was wondering how to make this method more efficient. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 30, 2009 Share Posted July 30, 2009 (edited) If you can't use the indirect method use the semi-indirect method. Once the barrel is smoking good (pyrolization is at or above 400f) put the lid (with the volatiles return pipe attached) on the barrel and let it burn it's own waste. Even using the direct method you should be getting better returns than 12-13%, 30-35% wouldn't be unreasonable. It still isn't great but it beats buying it. Nothing wrong with softwood charcoal, it doesn't last as long but it burns hotter. I know a number of guys who segregate hard and soft. They use hard for general forging and soft for welding. Frosty Edited July 30, 2009 by Frosty Quote Link to comment Share on other sites More sharing options...
781 Posted July 30, 2009 Share Posted July 30, 2009 I use the open barrel method and ussually get 40 to 50% return by volume. If I use smaller than 2X4 I get less You want the same thickness material raw wood not a mixture of sizes I use 2 X material about a foot longer than the barrel. I let this burn about 1 hour + or - depending on the wind. When mostly burned through or when you grap with a tongs it breaks I plug the 4 holes in the side and cover the top I then wet donw the sides and top of the barrel to cool and put out the flame. It is a battle of not burning long enough which leaves heavy chunks whick I either add to the end of the next burn or use them in the fore anyway if small or burning too long and getting less charcoal Try burning less time Quote Link to comment Share on other sites More sharing options...
