don1 Posted July 26, 2009 Share Posted July 26, 2009 Just saying hello, I'm new to blacksmithing. I,m a wood turner wanting to make some turning tools. I've made some in the past using a map gas torch. I have a forge and an anvil and a pole vice. Where can I get some swages? Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted July 26, 2009 Share Posted July 26, 2009 You can find a discussion on swages by clicking on:http://www.iforgeiron.com/forum/f83/swage-blocks-do-you-guys-have-them-if-so-do-you-use-them-much-13261/ You can find a information on making woodworking tools by clicking on:http://www.iforgeiron.com/forum/f23/helllo-13202/#post123052 :D Quote Link to comment Share on other sites More sharing options...
jeremy k Posted July 26, 2009 Share Posted July 26, 2009 Don -You can easily make some for what your wanting to do for making lathe gouges etc. Get a block of steel and drill a hole in it close to the edge with the same radius as you want the outside of your tool that will be forged. Then cut the block through the hole so you have a block with a half hole shape(your swage). Round off all the edges to about a 1/8" radius so there is no sharp edges, now you have yourself a swage block that can be used to form the ends of your tools. Do this on the same block (if it's large enough) for all the sizes you want to make, or make individual blocks for each size you choose. - JK Quote Link to comment Share on other sites More sharing options...
creek Posted July 27, 2009 Share Posted July 27, 2009 The Saltfork Craftsmen sell a swage block that is pretty reasonable and generaly only requires a little bit of clean up and work to have a good swage. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 27, 2009 Share Posted July 27, 2009 Don what country are you in? (Unless you are willing to pay for international shipping...) Do you want new or old ones? If old ones you should list sizes as you are dependent on what's out there. Note that listing the size of your hardy hole helps if you do not want to spend time converting them. Quote Link to comment Share on other sites More sharing options...
