Thanks for telling me where your photos were. Looks like you got things going there. Personally I would have tried to put the forge in near the middle of that side of your shop because of that long material issue. My shop is about 16 1/2 feet wide inside and the forge is in the middle of it. That seems to work out pretty good so far. I agree with shorting your blower pipe there too. My blower is on a stand with a flexible duct so if I have something weird shaped and it needs to be moved a little bit to the side or whatever I can. Also if you plan on putting a heater in your shop I would suggest making a blocker plate to put over the opening on your hood. Because if you are not needing your forge right away when you are out there, or just trying to get it warmed up inside to work, your heat will get sucked up and out the forge chimney I found. All you need to make it out of is some light gauge tin. I will try to get my daughter to do some photos this Sunday and I will post them for you to check out. And you do need a poker or two too. That was the first thing I made I think. I am going to be putting a high velocity stack cap on my forge chimney this spring too, it will increase the draw on the chimney, so that bugger should almost suck a basketball up it then. Good going!
