Forges 101
"So, we see that circulation is a weak secondary concern, which should be balanced against other factors, such as how far the flame can go before impinging on first surfaces. With a hot-face wall that is only a thin coating, you must aim the flame to impinge on the cast refractory or kiln shelve floor. You would still want to avoid your work pieces, but would also want it to strike as far from the wall it will bounce toward as possible. In that case, I prefer to aim the flame at the near edge of the floor, with only enough angle to assure that it will bounce toward the far edge of the floor, and continue up the wall." This statement came from my belief that what I observed to do very well, must be right; which was, of course, quite wrong After several more years of noting people aim burners at the far edge of the forge floors, I must admit that it is the better choice. My original positioning worked so well, because the burner worked so well; not because my choice of position was best.
Problem with lighting burners on new Forge
My bad about the "T" fittings. Lesson learned I like the work you did on the insulation and flame surface. Ending up with a "D" shaped interior inside a cylinder is smart. It won't end your burner problems, but turning the air intakes ninety degrees would probably help. Hang in there; things will all work out. It might help to figure out what is going on, if you change out the MIG tips for smaller sizes...
- Advice for my ribbon burner forge design
You need to replace your "T" fittings, which are completely WRONG, with the right fittings. Your present fittings have the same size center exhaust hole as the two end entrance holes; it is supposed to be at least one size smaller than the two entrances. Why? Because this little bit of constriction increases the swirl that the opposed entrances create. This swirl is needed to properly mix the incoming air with propane. So, your present fittings will never work worth beans!!!
1. The inner diameter of the forge (145 mm) feels fine to me, since I will not forge anything that requires a larger volume. However, is it better to change it to improve things like circulation? I think you will find that your ribbon burner is simply too large for the space you plan to use. You would do better to increase the space 25%, or reduce your burner that much. 2. The thinnest parts of the refractory (15 mm and 20 mm) is something I made up on the go. What is the recommended minimum thickness? Fifteen millimeters should do just fine. 3. I plan on cutting the tank into three pieces and casting them separately, but what about not cutting off the back and casting it as a whole? Anyone who have tried that? What about not cutting anything, and simply casting each area, one at a time; then whetting the surface of the cast areas, before casting the next sections against them. 4. I currently plan on having 2 layers of ceramic wool in the middle section. Is this overkill? Only having one lets me have thicker refractory. Thicker refractory is okay, only if that refractory is a high alumina type, with something included in it to create air voids. That something can be as basic as Perlite, or high tech bubble alumina. 5. Some people cast room for firebricks, some don't. Is there really a big need for this, since the forge will be cast in refractory either way? If people use their forges daily, I could understand, but I will definitely not use it that much. For some reason, I wouldn't even mind having a circular inside of the forge instead of flat to enable better circulation (OCD reasons lol). Forget the firebricks, and use a high alumina kiln shelf, from a pottery supply store, instead. The shelf can simply lay on top of the floor, and extend outside the front and back openings, to serve as the porch you want. When covered in hardened fluxed, it can be removed, so the flux can be removed with a wire wheel. As to avoiding a flat floor area, to improve circulation, you are over thinking the problem. Circulation does just fine in loads of forges with flat floors.
Forges 101
It is wise to buy your hose from a local supplier, rather than on line. It is even wiser to avoid Amazon ‘deals’ on hose and regulator combinations; many of those regulators have built in constrictors, to reduce gas flow to barbecue grill volumes. A 0-30 PSI Fisher regulator only costs about five dollars more than the so-called bargains, and will run trouble free for decades.
I agree with Buzzkill. Also, while larger is generally not better, a little larger to ensure enough room to do your work is a good idea. Furthermore, I believe that ribbon burners heat larger equipment interiors better than highly restricted ones, so a little more interior room is offset by that tendency too. Finally, the inner shape of your forge need not be determined by its exterior. Some guys are building "D" shaped forges in cylindrical shells; just a thought.
Forges 101
Avoiding flow limiters Bureaucrats being what they are, some states took federally mandated over-fill valves as an opportunity to quietly add an internal flow limiting device to the OPD valve, on five-gallon and other small propane cylinders; when used on a barbecue grill, flow-limiters should not create problems; when used on other heating equipment (which all demand much higher flow rates), they cause major problems. Check with your local propane dealer to see if you live in one of these states, and avoid fuel cylinder sizes with internal flow limiters. Instead, keep your equipment and hose in good condition, to avoid leaks. Be careful not to crimp or accidentally cut a fuel hose, by positioning it out of harm’s way; running the hose through hooks along walls or from the ceiling is a simple way to keep it from damage. Stainless steel braided hose is armored against such damage.
Burners 101
The Mr. Heater fuel filter came today, and proved quite a surprise; in the advertertisement photo, it looks small; its body measures 2-1/8” diameter by 1-3/4” long. This leaves plenty of room to hold tars and waxes from propane fuel, before needing discarding. This is important, because once filled, a filter becomes worse than useless; it becomes a clog. Caution: Newly constructed burners must have their gas systems thoroughly cleaned from all construction debris, dust, etc. Otherwise, it will inevitably end up plugging the gas orifice. Once, propane has been run through gas hoses, and regulators, they should be kept on the heating equipment, or have their ends capped. Insects and spiders are attracted by the methyl mercaptan odorant in propane.
Burners 101
A Mr. Heater #F276163 Fuel Filter can be screwed into any burner system between a 16 oz. fuel canister and a fuel hose, eliminating the problem of tiny gas orifices being plugged up from fuel tar and wax. However, with screw in gas orifices, such as MIG contact tips, or all but the smallest 3D printer nozzles, they are an unnecessary expense. But, with gas orifices that are so tiny that torch tip cleaners, or even piano wire is not small enough to work, such filters seem to be the logical solution. However, Frosty and I missed these filters in the for place, and I don't want to try for a twofer. So, if anyone has something else to say on the subject, please speak right up
Burners 101
Oh come now; surely you at least have a speck of embarrassment left, right? I have enough left to serve as a fig leaf; even if there is no where near enough remaining to scrounge up a blush
Burners 101
How embarrassing Good thing we never claimed to know everything, huh? On the other hand, if there was nothing left to learn...what a bore.
Best economical burner ready to go
You can buy Chile Forge burners, and while expensive, they are worth every dollar. However, I think they only market 1" size burners; that is very large for the average forge. A 1" burner is the equivalent of two 3/4" burners.
Burners 101
I ordered one through Amazon.com, yesterday. There is quite a range of prices for the same item.
Burners 101
Oh, goody! Thanks, Jeff. I had no idea the problem had such a simple solution. Will look into the Mr. Heater filter
Burners 101
Plugs and inclusions: Propane comes in widely varying quality from different sources, but even the best of it is not perfectly clean (we aren’t talking about triple refined butane lighter fuel here). The waxes and tars that all commercial propane contains, can plug small orifices on MIG contact tips, and the even the smaller orifices of 3D printer nozzles; ruining burner performance, while rapidly increasing pressures on gas hose and gas fittings to full cylinder pressure, unless a proper regulator—not just a needle valve—is employed. Poor quality “bargain” propane can form tar balls quite rapidly. It then becomes necessary to shut down and clean the burner by poking the tar ball out of its gas jet with a set of torch tip cleaners (or piano wire for very small orifices), and blowing it back out through the larger diameter gas tube with air pressure; canned air is fine for this, if you do not own a compressor. How likely is this problem to happen? The answer has more to do with your burner's gas orifice diameter than to propane quality. I only know of one instance of low-quality propane plugging a MIG tip orifice (with a 0.031" through hole. On the other hand, small commercial propane torch-heads, which depend on tiny gas orifices to work (0.004" and less), are commonly plugged shut by as little as two or three 16 oz. canisters of propane. Newly constructed burners must have their gas systems thoroughly cleaned from all construction debris, dust, etc. Otherwise, it will inevitably end up plugging the gas orifice. Once, propane has been run through gas hoses, and regulators, they should be kept on the heating equipment, or have their ends should be capped. Insects and spiders are attracted by its odorant.
Yes. You got the idea I was trying to get across, just fine however, considering what you described as the work you want to do with your forge...you may want to just run their forge as is
Burners 101
Why small, why stainless steel, & why linear burners? Why small burners? Combustion gases begin to slow, as soon as they leave the flame envelope. The flames of two 1/2" burners will use the same amount of fuel to produce an equal amount of heat as a single 3/4” burner; but they will drop velocity much faster in a five-gallon forge or casting furnace, increasing efficiency, because their flames can burn faster/hotter without creating a wasteful tongue of fire out the equipment’s exhaust opening. Ditto for two 3/8” burners versus a single ½” burner in a two-gallon combination forge/furnace, or two ¼” versus a single 3/8” burner in a one/gallon forge/furnace. Because the parts and tubing these burners are built from, cost less as their sizes reduce; it costs little or no more to make two smaller burners than a single larger burner; only the price of an additional funnel shaped air entrance is added on smaller burners, along with the cost of a second mixing tube on larger burners. When buying from online sources, it is usual to find two or three small tubes offered for very little more than a single part of the same size. Why stainless steel? Once again, the sellers are determined to make a certain amount out of each sale, so you will find stainless costs little or nothing more than mild steel, but is of far better quality. Several years down the road, your stainless steel burner will still be in fine shape; not necessarily so, with a mild steel burner. Why linear? My reasons for choosing linear burners are complicated, but the bottom line for you is simple; as burner sizes decrease, linear burners run more smoothly than any other design. Considering who just made this statement, maybe it deserves some consideration...
The problem is that good burners come and go in the market. Right now, they have mostly gone. You can still buy a Mister Volcano burner, by purchasing the forge it's in. Considering how low the price of their forges are, and how good their burners are, that is still a great deal. I believe you can still buy "Z" burners from Zoeller Forge, which are good enough. For any other burners presently being marketed...its a crap shoot.
Burners 101
All miniature pipe cutters aren't created equal The Saillong Mini Steel Tube Cutter (No. 174-F), with two spare cutter wheels and “E” spring retaining clips, are recommended for tube diameters from 1/8” to 1-1/8” (3-28mm); it is used for parting copper, brass, aluminum, and thin stainless steel tube (up to1/16” thick); $10 from Amazon.com. This cutter is not a necessity, but is quite handy, both for parting tubing, and for scribing perpendicular lines, (for cutoff discs) in the larger tubes or pipes chosen for flame retention nozzles in 1/4”, 3/8”, and ½” burners. This is the best quality I have found in a miniature pipe cutter, and yet it is offered at a low price. The cutter wheel on my 174-F, tracks perfectly (no wobble), and so it takes no special care to maintain a single cut line in the material, rather than fighting a tendency for its wheel to leave a spiral score on the material, instead of immediately starting a proper cutting path.
Jymm Hoffman Blown Burner search
Yeah; I spend most of my limited energy weeding the garden, these days
Wherever we start from, creates its own particular path of limitations. I started from highest flame velocity, as a way to promote highest flame temperatures, without adding oxygen. So, increasing the length of the exhaust path was the obvious way to increase hang time. Then, I added multiple smaller burners, to hedge my bets; it worked well enough that, I have slowed exhaust gases down to the limit, which is the amount of exhaust gases generated. I see no way around that barrier...at present. You started out with slower and larger flames, which did not need anywhere near as much breaking to meet the same goal; to lower exhaust losses to what is absolutely necessary. Despite our different starting points, we have used the same strategies to attain the same goal; all the efficiency we can manage in our fuel bills, while attaining sufficient heat to do the job. The final solution, no matter what burner design, will always be multi-flame burner heads, since the smaller each individual flame is, the faster it slows to a walk Once this is perfected, hotter fuels and added oxygen are the only paths forward; but that is a ways down the road, and I am an old man. Someone else can go there.
What I have found to be the biggest surprise, is that too much airflow from fans screws things up far more often than too little flow.
I only remember what was going through my head when the conversation fizzled out; that was fine control of the flames, and thougts about how to successfully use Kast-O-lite 30 for constructing burner heads similar to Gibson's. That would take casting the heads in two parts, introducing vibration during the casting, to get smoother surfaces, and coating internal surfaces with Plistix 900 for final smoothing I think fine flame control will require 12V to 24V fines, and speed control circuits. "fines?" That should be fans.
