one of the tricks that has saved me lotsa greif & time is the mounting bracket & saw table i made for my 9" right angle grinder. just a peice of 2" angle iron mounted to the right side of the grinder with a bolt in the hole were ya screw the handle on & a hoseclamp around the body & now the grinder can be mounted in a vice. add a flat plate with a bolt in the other handle hole & a couple nubs welded on to keep the plate from turning & now its an abrasive tablesaw. (be careful its alot easier to run yer knuckles into that 24 grit rock when yer holding the work & not the grinder!). OWWW! that & the $20 "weed burner" from harbor freight. its a big propane torch used by roofers & stuph but if ya look at it right its not only a big tempering torch for swords & stuph but also can be modified into a forge burner, its 6' of hose w/fittings, needle valve, jet & a half finished ventury all for less than $20! :)
