Good Morning,
If you haven't made tongs before, there is one rule you must learn. Left, Left, Left or Right, Right Right, Not a Variable!!
1 - Start the jaw on the near side of the anvil, half faced blows to set the shoulder, enough material for whatever jaw design you wish. DON'T MAKE THE BASE OF THE JAW TOO THIN!!
2 - "TURN 1/4 TURN LEFT" if you are right handed or "TURN 1/4 TURN RIGHT" if you are left handed. On the far side of the anvil at about 30 degree angle, at the shoulder that you had made in the first step, half faces blows to set the start of the hinge area, with an angle so the two halves of the tongs won't bind up an the base of the jaws. DON'T MAKE THE HINGE AREA TOO THIN, Minimum 1/4".
3 - "TURN 1/4 TURN LEFT" if you are right handed or "TURN 1/4 TURN RIGHT" if you are left handed. On the far side of the anvil at a 90 degree angle, at the end of the hinge area, half faced blows to start the base of the reins. DO NOT MAKE THE BASE OF THE REIN TOO THIN!! Start to draw out the rein, about 2-3 inches, Turn the tong end for end, grab the jaw of the tong with other tongs. Start to draw out the rein from the base of the rein, NOT THE END/TIP!!! Work about 3 inches at a time, draw the taper and break the edges of the rein as you go (IMPORTANT). When you have two reins done, match up the lengths of the reins, draw out or cut a little off of one and redraw to match length.
4 - Punch the hole for the rivet. I use 3/8" material for the rivet.
5 - Make a rivet from 3/8" mild steel in a header. Allow approx. 2 diameters long for the head of the rivet (3/8=3/4")
6 - Finish the shaping of the jaws. Can use a bolt and nut in the rivet hole to check the jaw shape.
7 - Heat up the rivet, use a rivet block on the anvil to support the rivet head (from damage). Put the rivet through both tong pieces (the tong pieces are not hot) and quickly hammer the rivet to form the other head. At this point the tongs are seized together with the rivet.
8 - Heat up the hinge area of the tongs and gently work the ends of the reins until the hinge is free. Put a piece of 3/8 round at the base of the reins and gently squeeze the reins to bend the reins so they will hang on the tong rack without the reins sticking out. Align the jaws to the shape you wish.
9 - Heat up the reins close to the hinge area and pull the reins, left rein to the right, right rein to the left, While holding the new tongs in a vise. Hold the point of the reins where they cross, with another set of tongs, and bend the left rein left and the right rein right. This will align the reins over top of each other and will allow anyone to use them, right or left handed.
10 - Finish the reins like you are PROUD of them. Give them the BRAILLE test, close your eyes and run your hands over them. THERE SHOULD BE NO SHARP EDGES on the reins. There should be lots of material at the base of the reins and jaws (the fulcrum point is the rivet. If you squeeze the reins it should not bend at the base of the jaws or reins).
11 - I make all my tongs from mild steel (preferably). This way you won't have the tongs crack if you accidentally quench them while hot.
The rule for drawing out anything is S.O.R. Square, Octagonal, Round.
Enjoy the journey, Be Proud of what you make.
