Youngdylan,
If you have seen the videos of the Kinyon style hammers with the Coleman controls you can probably understand what I’m trying to say.
The Colman style uses a rod which moves up and down with the tup. On this rod is a contrivance which contacts the limit switches striking them independently to open and close them and tell the pilot valve shuttle to send air to and exhaust one end of the cylinder or the other, these two switches are located one above the other on one side of the rod. Tup stroking is controlled by moving the switches further or closer apart.
Now on the Bull style. Imagine this rod is configured at say an angle of 15*from vertical. The switches are placed, one on the right side and the other on the left of this angled rod. The switches do the same thing as in the Kinyon style they tell the pilot or spool valve in a five way valve which end of the cylinder to exhaust and which end to pressurize. This rod is connected to the treadle, as the treadle is depressed it opens the main air supply and moves the rod bottom rearward at the same time. As the rod moves back it contacts the switch that is for downward motion of the tup. The upper end of the rod is connected to the tup (remember 15* angle) and both ends of this rod can pivot around a bolt. This rod is made of two pieces, a square tube in side of which a 3/8” round rod slides. This means the rod can lengthen and shorten as the tup moves up and down. Simultaneously as the tup comes down the rod is shortened and because of the angle as it is shortened the angle must increase say to 25*. This pulls the rod away from the down motion switch and it now contacts the up motion switch as long as the treadle is held down the rod will oscillate between the two switches and the tup will continue to cycle.
The harder the treadle is pressed the more air is admitted through the main valve and the faster the tup goes up and down.
To try and draw a sketch of this for yourself draw a line slanting from bottom to top to the left at about 15*. Now place dots to the left and right of this line, the one on the right just a bit higher than the one on the left. Place a ruler on edge on this line and twist it to simulate the motion of the rod in the hammer and notice how it will contact one dot and then the other as you twist from the 15* angle down to the 25* and back again.
If this is still unclear ask Ciladog if he can send you his shop drawing or a straight on pic of the inside of the control box
PS I guess Ciladog beat me to the answer so here's a similar explanation
Doc.
