Forged my first pair of tongs
texascherokee
Looks like 1/4" x 1" twist with the reins arc welded on. Serviceable, but wire brushing hot would slick them up and improve their looks.  To be honest they are better than several pairs that I made when I started making tongs, and as good or better than some that I have made recently ;-)  Jr Strasil (his login was irnsrgn) had a trick where you  do a lap weld with the arc, or a mig, or whatever, fill in the filet on both sides, then you get it hot and forge it flat. Often times if you do it right it is hard to tell it is not a proper forge weld;-) Good job, Thank you for your service.
  • 2 weeks later...
  • 3 months later...
  • 2 weeks later...
Jr Strasel had a neat trick that he recommended.  If you overlap the ends just slightly, then do filet welds, you can get it all hot and forge it out and it will almost look like a forge weld.  Lots of ways to get the job done, find something that works for you, your tools, and your skill level, hopefully it will end up being aesthetically pleasing as well...  Always strive to do better.
