Fire Pit Screen
Double Y
This is a custom Fire Pit Screen for a family who's last name is Ford.
The concrete pit was poured and I had to make a lip for the screen to rest on.  I worked a piece of 3/4 x 3/4 angle iron the hard way to be inside the pit.
The dome is made from 1/4 x 2 flat.  The pit has a diameter of 36 1/4.  There are doors on each side that are latched with magnets.
The Ford logo on top has a bearing to allow it to swivel.
The leaves are all hand forged, but I mig welded them together and to the frame.
I shot the works with stove black rattle can paint.
They just need a roaring fire to test it out.
Thanks for looking,
John
post-5371-0-97236600-1415205098_thumb.jp
post-5371-0-71454900-1415205104_thumb.jp
post-5371-0-14135000-1415205112_thumb.jp
post-5371-0-59367500-1415205118_thumb.jp
post-5371-0-57408100-1415205125_thumb.jp
I built the frame obviously first.  I suspended the frame off my layout table by the corners and worked the screen down.  I used spring clamps to hold the screen in place and then started tack welding.
It went pretty smooth with just a bit of massaging needed in the corners.
Thanks,
John
  • 3 weeks later...
