Dave English Posted March 11, 2009 Share Posted March 11, 2009 In my Materials Handbook, 1956, is a description of ingot iron that's used for special purposes, electromagnetic cores, boiler plate, for water tanks. It often has very low carbon, .02%, but can be as high as .15%, it's rust resistent. How does this weld? Is it like wrought iron where the two pieces actually are welded together or is it more like or mild steel where it's more of a surface weld? Quote Link to comment Share on other sites More sharing options...
TASMITH Posted March 12, 2009 Share Posted March 12, 2009 If it is the type of steel used for electrical cores,such as transformer cores, and such it will be a lower level of carbon, BUT, it will contain high levels of silicon. I am not entirely sure how this will forge weld as I have never tried it but the silicon will no doubt change the effect of the weld and perhaps make the weld joint weaker. I do know that the silicon levels are up around 5 or 6% and maybe Quenchcrack may be more up on this effect. Terry Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 12, 2009 Share Posted March 12, 2009 I just picked up some transformer core lams to use in a bandsaw blade billet and compare them with the pallet strapping I usually use. If I don't get the poles for my shop extension set this weekend I'll try it out. Quote Link to comment Share on other sites More sharing options...
Dave English Posted March 12, 2009 Author Share Posted March 12, 2009 This is very pure iron, not steel, such as Armco ingot iron of the American Rolling Mills Co in 1956, is 99.94% pure iron. I don't know if transformer cores are the same but I believe it would be of some type of pure iron. The reason I ask is that iron cores in scrap large electric motors and generators may be worth locating if the the iron forge welds like wrought iron. Quote Link to comment Share on other sites More sharing options...
Paul B Posted March 12, 2009 Share Posted March 12, 2009 If you are taking the iron from large oil filled transformers, be carefull of the PCB's. Quote Link to comment Share on other sites More sharing options...
Dave English Posted March 13, 2009 Author Share Posted March 13, 2009 I just spent about 20 min writing a detailed reply and was told I had to log in (I was already logged in) and as you may have experianced yourself, the reply was lost in cyber space never to be seen again. This is about the 6th time this has happened, I should have 48-49 posts, not 42. My best posts are ...... Quote Link to comment Share on other sites More sharing options...
Iron Falcon 72 Posted March 13, 2009 Share Posted March 13, 2009 I try to remember to copy any long post to a word processor before hitting post. Good luck in the future. Quote Link to comment Share on other sites More sharing options...
matt87 Posted March 13, 2009 Share Posted March 13, 2009 I have been told (by John Bellamy) that transformer core iron is basically pure iron, the same as is marked to blacksmiths, e.g. here: Pure Iron - The Core Element It's softer/more ductile and easier to fire-weld than mild steel but John says it's a lot more thermally conductive than steel so you will need tongs on pieces you wouldn't if it were steel. Quote Link to comment Share on other sites More sharing options...
Dave English Posted March 14, 2009 Author Share Posted March 14, 2009 I had posted how the core of transformers can be steel, air or pure iron, dependingon thier use. The Navy uses steel in plates for the most part so scrap Navy transformers should have steel cores. Iron cores can be found on -20 KHz, smaller tranformers, but I don't know if a smaller transformer is 2 pounds or 200 pounds. Quote Link to comment Share on other sites More sharing options...
